× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 Losing WAN Connectivity via WiFi Multiple Times Daily
Lazydayz137
Tutor
XR500 running the latest firmware, don't recall the version, but the one that enabled "hybrid vpn." I lose WAN, or internet connectivity to all WiFi connected devices multiple times a day. LAN connection still works. Usually it comes back up in 10-15 minutes, but believe it or not, there are WiFi only users that find this unacceptable. And as the purchaser of a pricey router, I also find this issue unacceptable. I've tried various settings within the firmware after reading numerous threads on the subject, to no avail. There also appears to be a firmware fix for this issue floating around, so if there is, a link would be awesome. Otherwise, any other suggestions, tips, or tricks would be much appreciated! Thanks so much!
-Lazydayz137
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 6
Netduma_Alex
NetDuma Partner
Re: XR500 Losing WAN Connectivity via WiFi Multiple Times Daily
Here's the firmware hotfix you're referring to: XR500 Firmware Version 2.3.2.32
Hopefully that fixes the issue. If not, let us know.
Message 2 of 6
Lazydayz137
Tutor
Thanks!  I was using a newer firmware version.  Shame the fix didn't make it into that.  But, knock on wood, I've been running the firmware you linked for a couple days and haven't experienced any disconnects. If we can get a few more days of uninterupted service, I'll mark this as an accepted answer.  Just don't want to be too hasty, because as soon as I am, it will start dropping left and right.  Thanks again Alex!
-Robert
Message 3 of 6
Netduma-Fraser
NetDuma Partner
Great to hear that, keep us updated!
Message 4 of 6
Lazydayz137
Tutor
Sorry for the delay in replay. I'm in the middle of a move between cities and it is super hectic.  I must not have knocked on wood hard enough, because almost immediately after posting that the fix seemed to be working, the drops started again and have continued to this day.  Not much else to say on the subject, as you can imagine.  But wanted to update you guys in case you had another fix up your sleeve.  Thanks so much!
Message 5 of 6
Netduma-Fraser
NetDuma Partner
The link given wasn't actually the hotfix, sorry about that. Please try this instead: https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
Also good luck with the move!
Message 6 of 6
Discussion stats
  • 5 replies
  • 1235 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
