- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 Nighthawk - Flashing power light - Firmware issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Hoping someone might be able to help as I'm currently at my wits end with my router and Netgear! I've seen this problem floating about in several discussions but i've tried everything to remedy the issue but to no avail.
I've got the Nighthawk XR500 Gaming Router currently displaying the problem of the power light blinking. I'm not sure how this has come about however after a quick search on the internet and in the forums it sounds like there is a firmware issue.
Once i had diagnosed it i tried several times to re-install the firmware using the tftp2 method however when i start to flash the drive the blue progress bar gets halfway and says that there is an issue connecting to the server. I'm having to hotspot off of my personal mobile in order to download the firmware files which is less than ideal.
I've contacted Netgear's "support" and spent 45 minutes on the phone re-diagnosing what i already knew to be told that i would have to pay around £100 to get further support even though I've got hardware warranty on the product! Sent a complaint email to them which has been ignored so I'm not sure what else to do with a router i've spent in excess of £250 on other than throw it in the bin...
Hoping someone might be able to point me in the direction of a fix!
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Nighthawk - Flashing power light - Firmware issue?
many things can go wrong using tftp as well as its sensitive to timing. Sometimes you have to try several times.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi!
I've tried the Tftp method again however still no joy. It seems to get halfway before saying that its not getting a response from the server. I'm holding down the reset button whilst i power it on and waiting for it to flash 10 times as per the instructions and tried different time intervals but nothing seems to work?
This is where it gets to before it stops.
and then this is what i get when it fails
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No worries, hope i've done this right as i've never used Imgur!
https://imgur.com/a/QKUp3cQ
- Mark as New
- Bookmark
- Subscribe
- Permalink
have you tried nmrpflash?
I've had luck with that when tftp wouldn't work
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can give it a go. Do you have any references to tutorials on how to use/download nmrpflash at all?
Much appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
for the most part, tftp has worked well for me. There's been probably 2 occassions where it didn't and nmrpflash did. There's instructions at the site on using it.
