Orbi WiFi 7 RBE973
Reply
XR500 OpenVPN suddently not working
MrSwann
Hi all
My OpenVPN server suddently stopped working, can’t connect.
I tried with ddns, didn’t do anything. I tried redownloading configs, didn’t help either
What can I do ?
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: XR500 OpenVPN suddently not working
Has any part of your setup changed - physically or setting wise? What is your exact physical setup?
Message 2 of 4
MrSwann
No, i got the unit and ran the setup etc. It worked fine for about a day, then it stopped working. Not I can’t connect either via phone nor pc. Also the profiles for pc doesn’t work, so I tested using mobile profile and that also worked shortly as I recall
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Whatever VPN client you're using to connect with these configs does it provide you with an error log? If so could you provide it please? Also I should note that I'm from Netduma so we didn't make this feature but I'll do my best to help.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1002 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
