× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
XR500 PC disconnects
NDwsn
My pc has been intermittently disconnecting, I have tried a new Ethernet cable, and I have tried it in every port on the router. Nothing else disconnects, not my WiFi or other wired devices. It sometimes only happens once or twice , sometimes constantly for an hour or so. Sometimes it disconnects for like 5 seconds other times for like 2 mins. There is no pattern. I have noticed that when it’s happening the corresponding Ethernet light goes orange. I have tried factory resetting the router but I just can’t work it out.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: XR500 PC disconnects
If you connect the same PC to WiFi, do you experience the same issue?
Message 2 of 4
NDwsn
I don’t have a WiFi card in my pc to try that but as I said all the other devices on my network remain connected to the internet when the issue is happening
Message 3 of 4
Netduma-Fraser
NetDuma Partner
If you connect the PC directly to your ISP hub/modem do you experience the same issue?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1052 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
