× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
XR500 Parental Controls
aeloen
Hi,
Is there any update as to when parental controls will be delivered for the XR500?
Thanks
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 12
Netduma-Fraser
NetDuma Partner
Re: XR500 Parental Controls
If you upgrade to the 3.0 beta then you will have access to the Parental Controls (Traffic Controller).
Message 2 of 12
aeloen
Hi,
Thanks for your reply. I've had the router 24 hrs, where can I get the beta from?
Appreciate your help.
Message 3 of 12
Netduma-Fraser
NetDuma Partner
Message 4 of 12
TBigJohn
Hi, Are you sure it's possible to use this Beta 3.0 on XR500 ?
Possible to have a direct link to the right version ?
Thanks
Message 5 of 12
Netduma-Fraser
NetDuma Partner
Yes absolutely certain, here is the latest for you to try https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0
Message 6 of 12
TBigJohn
Ok so .114 is intalled, is it then now possible to control anyway how much time each device can stay conntected ? Thanks
Message 7 of 12
Netduma-Fraser
NetDuma Partner
Yes you can set a schedule for each device if you would like using Traffic Controller.
Message 8 of 12
TBigJohn
Hi,
Is it possible to see the log of the web connection of a specific device connected to the network ? All URL visited
Thanks
Message 9 of 12
Netduma-Liam
NetDuma Partner
You can see when rules were activated and deactivated, and there's a log of that happening, but you can't see specific URLs requested etc.
Message 10 of 12
TBigJohn
Which Netgear model can you recommand in order to achieve this kind of control ?
Message 11 of 12
Netduma-Fraser
NetDuma Partner
As far as I am aware there isn't one that does this. However, we're from Netduma who created DumaOS for the XR range so we're not as knowledgeable on the other models. If you post here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk they may be able to give you some advice.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2711 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
