- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 Rebooting Itself After Attempts at Streaming and Downloading
- Mark as New
- Bookmark
- Subscribe
- Permalink
As the title says, for some reason my new Netgear router is crashing non-stop whenever I attempt to use my WiFi to stream or download games for my console. I've had this device since last month and I switched Internet providers at the same time, so I assumed it was my new modem. Nope. After attempting to watch my smart tv, the router crashed and entered a reboot state, and my modem was doing perfectly fine. I don't know why it's doing this, and any help would be great.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting Itself After Attempts at Streaming and Downloading
Could you please go to Settings -> Setup -> LAN setup and change the minimum DHCP pool address to 192.168.1.50.
Then add IP address reservations for each device on the network, make sure you give each device a different address between 192.168.1.2 and 192.168.1.49.
After that check if the problem still occurs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There's no "minimum". I have "Starting IP address" and "Ending IP address", then I also have IP Subnet Mask. I'm completely new to all of this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Alright, I changed it but nothing happened. I think I should mention that my PS5 and smart TV are connected via wireless, not cable, as they're not within cabling range of my router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeahh, I'm going to keep this up for a while. I'm trying to find a solution that doesn't keep resulting in the router crashing when I try to download things or stream.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Coming back to this: I followed the instructions provided here and nothing has changed. My downloads are still causing the router to crash and enter a reboot state along with streaming. Really wondering if I have a screwed system but my PC is fine with it being directly connected. It's specifically an issue with the WiFi that the router provides. I even plugged it directly into my wall socket, as told by a rep on the phone, and that didn't do anything to help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What settings have you changed specifically since you first set up the router or have you not changed anything and left it all as the default?
