- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 Rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
XR500 Rebooting
Hello,
I have an XR500 running 2.1.0.6. Over the past week I have noticed that randomly the router will reboot, during this time all wired/wireless connections drop and I can't access the router. It then comes back up and it works, it might work for a day, or it might reboot again 10 minutes later.
Has anyone else had that happen? I purchased this unit on Jan 9th and its just this past week I have been having issues with it. Nothign has changed in my enviroment in the past week.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
I'll send you a PM, please continue to monitor the situation and see if that resolves the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
Hi TWISM,
I just wanted to check in and see if your issue has been fixed.
Please let me know. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
No, it hasn't been fixed.
I will admit I called into support and it was a frustrating experience. I know they are there to help but I wish at times when you are not the average end user you were able to bypass all the basic tasks. I had to reset my router while they were on the phone, downgrade the firmware, detail to them what was on my network. They blamed everything but the router, it was a power issue, it was Amazon echo devices (how many and what model Amazon devices do you have).
Right now I am just dealing with a rebooting router until I have the time to call back in and go through the motions. I did downgrade, and reset and am just checking in to capture times when it reboots.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
Hi TWISM,
Please do a factory reset on your XR500 device.
Hold the reset button located on the back of your device for 10-15 seconds. Next, Let the device boot all the way up.
Please let me know if this fixes your issue. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
This will be the 4th factory reset as I have reset it after every firmware upgrade/downgrade I have bene instructed to do. Will report back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
Hi TWISM,
Thank you for your response. :]
Have you done a factory reset from your last upgrade?
Yes, thank you for letting me know when you finish with the factory reset.
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
Hi TWISM,
I just wanted to check up on you and see if your issue has been fixed.
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
It’s been reset about 5 times. It’s had firmware upgrades and downgrades.
Not sure what else to do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
Thanks, will test this new FW out and report back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
Has this been resolved for you? I am experiencing the same sporadic reboot issue and it’s most frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
The latest FW has seemed to fix the issue for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
I have reinstalled the newest firmware, but my router only made it just over wi hours before rebooting again. I work from home and require a constant connection. This is getting too frustrating. 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
I am having the same issue as the original poster.
I am currently on
Firmware Version |
V2.2.1.10 |
I am forced to use this version because I needed VLAN tagging to actually work since I have fiber to my home through a GPON or ONT. When I first tried to setup my router, I had to plug my old one in and download the firmware to a USB then plug the new router in to update the firmware since I had the VLAN tagging 404 error.
I have fiber directly to the outside of my house (1,000mbps upload 1,000mbps download) connected to a GPON / ONT and CAT6 from the ONT to the inside of my house connected directly into the XR500.
No matter what I do with the QOS, GEO filtering, turning off 5g etc the result is still the same. My internet for the first few days would go offline and the router became unusable, where I couldn't login to the rotuer via webpage on any device connected to it every morning. Now it is doing it day and night sporadically. Last night at midnight it went off randomly while I was in the middle of a ESEA pug ong CSGO, while I was streaming live to twitch. This evening it went off randomly while I was typing up emails for work.
When I try to log into the router to look at the logs, I cannot connect to the router via webpage through 192.168.1.1
The only way to get things working again is to reboot my router. When I am having the issue all lights are normal flashing white, the only time they turn orange is after I hit reboot and the router is coming back up. This is extremeley frustrating and I tried calling Jason at level 3 but it was his day off. I am about 24 hours from taking this thing back and giving up. I HIGHLY suspect this is a firmware related issue that needs to be addressed asap, I am seeing the issue more and more as I search online for the solution. Also I saw somewhere someone mentioned being on a dynamic IP which most of are and when there is an IP change that could be the issue, or even something to do with the MAC address after the IP has changed...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
