× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 Router Mode - LAN ports requesting ISP DHCP address
gdadkins
Guide
Thought I'd make a discussion to see if anybody else is running into an issue similar to mine. I've been told by my ISP that I have multiple devices requsting DHCP addresses from my DSL modem, even though the router in configured in router mode and there is only one cable connecting from the labeled Internet port to the DSL modem. I've seen screenshots from their end showing MAC addresses requesting and sure enough, devices plugged into the four LAN ports are on the list.
I moved all of those connections behind a managed switch to see if that would resolve the issue, but the MAC address of the switch shows up as requesting an ISP DHCP address. I'm not sure how to troubleshoot it from this end as I haven't noticed any settings specifically that jumps out as to cause this if it's in router mode and not AP mode. I never had this problem on my previous wireless router (ASUS) with the same DSL modem for last couple of years.
I'm on firmware V2.3.2.40-C424a. This was occuring on the v.3.2.40 as well as the rolled back firmware as well.
Ideas?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 6
schumaku
Guru
Re: XR500 Router Mode - LAN ports requesting ISP DHCP address
Have by mistake any VLAN bridge or VLAN group configured to bridge the LAN port(s) to the Internet/WAN port - and bypassing the XR router NAT therefore?
Message 2 of 6
gdadkins
Guide
It's not checked as enabled. I'm guessing if it was enabled, a factory reset should fix that?
Message 3 of 6
schumaku
Guru
Yes, of course.
Message 4 of 6
Netduma-Fraser
NetDuma Partner
Has your issue been resolved since doing a factory reset?
Message 5 of 6
gdadkins
Guide
Performed a reset this morning. I’ll reply back to my ISP and see if only one device is showing up in the DHCP list. I was waiting until lunch time as the lease time is four hours, so I wanted to ensure it had enough time to lapse.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1282 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
