Reply
XR500 - Unable to configure product due to router keeps disconnecting from browser
MJMasters1234
I have just purchase this product and am unable to stay logged into router via web browser to configure
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 14
Guru
Re: XR500 - Unable to configure product due to router keeps disconnecting from browser
Be sure you are wired to the back the router with a PC.
Try a different browser, FireFox or Opera.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 14
MJMasters1234
The latest firmware, unable to confirm firmaware details as uanble to log on.
Virgin media superhub in Modem Mode
tried wire connection no difference
Message 3 of 14
Netduma-Fraser
NetDuma Partner
What happens when you try to login? Are you using the details set in the setup wizard?
Message 4 of 14
Xr500
Apprentice
The XR500, when I first sold it, I bought it, and until now its network disconnection problem has not been completely fixed. Smiley Sad
Message 5 of 14
Netduma_Alex
NetDuma Partner
Are you on the latest firmware?
Message 6 of 14
Xr500
Apprentice
yes
Message 7 of 14
Netduma_Alex
NetDuma Partner
Have you tried logging in with mutliple browsers? Or your current browser but in incognito mode?
Message 8 of 14
Xr500
Apprentice
◆ Google Chrome 75.0.3770.100
◆ Internet Explorer 11
◆ Opera 58.0.3135.53
I've considered browser impact before.
I've tried three browsers
Message 9 of 14
Netduma_Alex
NetDuma Partner
Could you try temporarily disconnecting the XR500 from the modem, so that it's just your XR500 and your laptop/phone connected to each other, and then try accessing the interface at that point?
Message 10 of 14
Guru
Have you tried a different PC to see if this problem follows?
Please downgrade to v32 and see if this changes anything. Seems like this maybe a PC issue rather then router issue as others have not posted about this. Possible the router could be faulty.
Message 11 of 14
Xr500
Apprentice
My family has two PCs, two iPhone 8 and five ZigBee devices.
They are all affected by router disconnection
It happens almost every 20 days.
Message 12 of 14
Xr500
Apprentice
When the router is disconnected, two iPhones 8 can connect to wifi, but they can't use the Internet.
Other PCs and laptops will be affected. I don't think it has much to do with PCs.
Message 13 of 14
Netduma_Alex
NetDuma Partner
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 1301 views
  • 0 kudos
  • 5 in conversation
Announcements
