× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 Upload speed low
Potatoman
Hi I am getting upload speeds of around 25 to 30 when I test though my pc (Ethernet connection) however when I test the speed through the netgear app I am getting my ISP promised speed of 45 to 50. I use two pcs both on Ethernet for streaming and gaming, so I need my upload speed high and stable. Any advice?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 20
Netduma-Fraser
NetDuma Partner
Re: XR500 Upload speed low
Can you provide a screenshot of your whole QoS please? Upload it as an attachment, then I'll see if there is anything there causing the issue
Message 2 of 20
Guru
What actual modem/gateway do you have?
Message 3 of 20
Potatoman
Message 4 of 20
Potatoman
Message 5 of 20
Potatoman
Message 6 of 20
Potatoman
Hi I'm not entirely sure, I'm on NBN in Australia and have FTTP
Message 7 of 20
Netduma-Fraser
NetDuma Partner
Does the modem/router have WiFi? Are ALL devices connected to the XR?
Message 8 of 20
Guru
That tells us you have fibre ran to your home.
What ont/gateway is the router connected to?
Message 9 of 20
Potatoman
How do I find this information?
Message 10 of 20
Netduma-Fraser
NetDuma Partner
Look on the box of what the XR500 is connected to and it should have a model name on it
Message 11 of 20
Potatoman
All I could find is G-240G-P
Message 12 of 20
Potatoman
Also when using wifi I am receiving a higher upload speed than if I am using a ethernet connection.
Message 13 of 20
Netduma-Fraser
NetDuma Partner
Can you check other ethernet devices and see what speeds they get please?
Message 14 of 20
Potatoman
I have two PC's both on ethernet connection giving similar results
Message 15 of 20
Netduma-Fraser
NetDuma Partner
If you click the menu top left of the Anti-Bufferbloat/Congestion Control panel and disable QoS fully do you get the speeds you expect then?
Message 16 of 20
Potatoman
No, same results, also when testing the upload speeds on ethernet it takes a few seconds for the upload speed to rise from around 5 to 28ish. Compared to wifi which is instantly 45+
Message 17 of 20
Netduma-Fraser
NetDuma Partner
Can you try directly connected via ethernet to the G-24, what speeds do you get then? Also what firmware version are you on currently?
Message 18 of 20
Potatoman
I'm getting full speed when connecting to the modem, my firmware Is the latest according to the mobile app.
Message 19 of 20
Netduma-Liam
NetDuma Partner
Thanks for confirming, were you connected to the modem using the same ethernet cable that you currently connect to the R2 with? If so, could you please try a different cable?
Message 20 of 20
Discussion stats
  • 19 replies
  • 2291 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
