× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 V2.3.2.40 Two Serious Bug
Xr500
Apprentice
Two Serious bug Reasons for appearance:
 Long-term uninterrupted Download
Two Serious bug Reasons for probability:
 Each Long-term uninterrupted Download
Two Serious bug Reasons for Interim solutions:
 Restart using Shutdown key
First Serious bug:
 Anti-Bufferbloat When operating all settings.
 Error prompt:RPC error 'ERROR_NOENT': Rule not found in chain
The second Serious bug:
 Internet Orange Lighting.
 5Ghz and 2.4Ghz White Lighting.
 Eth1 White Lighting.
 Mobile phones and Computers No network.The same is true of waiting a long time.
 And don't go in and Manage Pages. www.routerlogin.com Blank space nothing shows.
 Must be forced to restart using Shutdown key.
Smiley Sad It has happened many times. I need help.
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 16
Guru
Re: XR500 V2.3.2.40 Two Serious Bug
Has a factory reset been performed after updating to v40 then setup from scratch?
How are you determining these issues?
What does long term uninterrupted download mean? Are you having problems with downloads? Would need more details on this?
You might revert to v32 and see if anything is different.
First Serious bug:
Message 2 of 16
Xr500
Apprentice
Thank you very much for your timely reply.
  1. I don't know my ISP modem.Connection mode PPPoE.
  2. Updating a version will restore factory settings.
  3. WINDOWS 7 Computer Performs Download Task. The download software is BitComet. Download for about 20 hours. XR500 Problems arise.
  4. Previous versions did not have this problem.previous versions contained security vulnerabilities.
Message 3 of 16
Guru
Would need to find out modem model information.
updating FW does NOT restore factory resetings.
Message 4 of 16
Xr500
Apprentice
After the update is completed. I manually restore the factory settings.
I don't feel related to ISP modem model.
Because this network is provided by the company.
When the Internet lights are orange. management pages can't get in.
When the Internet is white. the management page enters normally.
Message 5 of 16
Guru
Reason for asking about model# is to check for model information about the modem your using and nat abilities.
What prior versions of FW worked for you?
Message 6 of 16
Netduma_Jack
NetDuma Partner
This error prompt on Anti-Bufferbloat:
This is very rare but can sometimes happen. Could you try rebooting your router. You shouldn't see it after that.
Message 7 of 16
Xr500
Apprentice
Thank you. Every reboot resolves all problems.
Message 8 of 16
Guru
Message 9 of 16
Xr500
Apprentice
Three months have passed.
My problem still exists.
i have tried many times Reinstall the FW .
factory reset been performed after updating to v40 setup.
Message 10 of 16
Netduma_Alex
NetDuma Partner
Are we talking about the first problem (anti-bufferbloat) or the second problem (can't access interface)?
Message 11 of 16
Guru
Try downgrading to v32, factory reset and setup from scratch to see if problem still happens?
Message 12 of 16
Xr500
Apprentice
The first problem (anti-bufferbloat)  is that it occasionally appears.
The second problem often arises.
Message 13 of 16
Xr500
Apprentice
OK,But my R8000 has never had these two problems.
But R8000 is not optimized for games.
Message 14 of 16
Netduma_Alex
NetDuma Partner
Have you tried this hotfix firmware? https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
It's specifically for dropouts so it might fix your problem.
Message 15 of 16
Xr500
Apprentice
Wow, thank you. I'll try.
Message 16 of 16
Discussion stats
  • 15 replies
  • 3092 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
