Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 XB1 PS4 Pro high latency - why?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-06-28
12:40 PM
2019-06-28
12:40 PM
Please help!
I have purchased a decked out setup to play competitive video games as this has long been a passion of mine. Here is my setup: BenQ Zowie monitor, XB1/PS4 Pro, XR500, Cat-6 Ethernet cables, and some $50 HDMI the sales people talked us into buying. Speedtest results are 478 Down 9 -19 up.
With all of this you would figure the internet would perform at least as fast as my opponents’. But it doesn’t, Xbox reads 68-71ms latency. Also, the speed numbers fluctuate very drastically. Please tell me what I am doing wrong!
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-06-28
12:56 PM
2019-06-28
12:56 PM
Re: XR500 XB1 PS4 Pro high latency - why?
What are speed test and latency results with a wired PC?
How do you have QoS or Anti BufferBloat set for?
What other devices do you have connected while testing speeds and pings?
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-06-28
01:08 PM
2019-06-28
01:08 PM
Thanks for the quick reply!
I am ignorant to Firmware at the moment. After a google search, I want to say there are none downloaded on my Route? Modem? I am not sure where to look.
Modem is Spectrum e31u2v1
PC Speedtest 478 Download 23.8 Upload
Not sure where to start with ABB. Whenever I adjust it, the speeds get lower. Literally no other devices are connected. I kicked everything off.
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-06-28
01:20 PM
2019-06-28
01:20 PM
Disable any QoS and ABB and test.
Selet the circle with the (i) on the upper right hand corner of the window and it should give FW version info.
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-06-28
01:36 PM
2019-06-28
01:36 PM
I restarted the router, so now all QoS & ABB settings are disabled. Firmware is V2.3.2.40
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-06-29
05:20 AM
2019-06-29
05:20 AM
Firstly, I would return those HDMI cables, cheaper cables will work just the same as the more expensive ones.
I assume you're talking about the ping/speeds from the Xbox settings in which case - the ping is just to an authentication server, its just to say you're connected to XBL - this is not your game ping and so I wouldn't worry about it. Console speed tests can be inaccurate and higher speeds will not increase your quality of gameplay - games use less than 1mbps.
Adjusting QoS will lower speeds in order to prevent local congestion, its up to you if you don't want to use it - you're unlikely to get much congestion with your speeds but if you did then with the feature disabled it wouldn't help you eliminate this.
I would recommend going through our optimal settings guide here: http://support.netduma.com/en/support/solutions/folders/16000090646
Message 6 of 6
Announcements
