- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 Xbox One X issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was previously running off wireless for my Xbox one X, but then ran into lag issues (which I blame the Xbox wifi card for). I finally then ran a cable to my xbox (100ft away), and it seemed to work until I turned the xbox off, then went to turn it back on again (with instant on enabled). I read the article here: https://kb.netgear.com/000060532/How-do-I-fix-disconnection-issues-with-my-Xbox-One-console-when-con... but would rather not have to turn instant on feature off, since it would drive my wife nuts. Is there any beta firmware I could try? Or would a Gigabit switch in between my Xbox and the XR500 solve it? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Xbox One X issue
The Instant ON feature bug is a MS issue. Not a router FW issue.
You would need to talk to MS about what your seeing with it enabled. It's recommended to disable it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah Figures it was MS... Do you know if the Insider Aplha Xbox releases fixes this issue? I'm hoping to try a switch in between to see if that fixes it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know for sure. My roommates box is on the Preview program. His is disabled however I can check to see. Something i'll try this weekend.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok thanks! I just put a gigabit switch in between the router and xbox, and that seems to have fixed it. Guess that's my workaround for now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Kewl, that works too. I'll enable the roommates feature has his is directly connected to the router.
Gb switches are good things.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
