× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 and Circle compatibility
DuButler72
If I purchased the new Disney circle box, will it be compatible with my Nighthawk XR 500? Also, does using the Disney circle device inhibit any of the nighthawks functionality and performance?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Guru
Re: XR500 and Circle compatibility
I don't believe circle is supporting of XR series routers. I would not introduce something that can inhibit gaming performances.
Message 2 of 3
Netduma-Fraser
NetDuma Partner
As above, I would assume in order to correctly control devices you'd have to do modem > circle > XR500 which would mean you'd lose a lot of the benefits of the XR500.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1292 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
