× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500, crash every 24 hour
LightManeye
Hi, from 2 months my XR500 V2.3.2.120, crash every day.
I have tried with a simply reset and a factory reset with a new config, but the problem returns promptly in 24 hours.
Im trying to disable ddos protection, use a dhcp with .50 start ip and i have change the wifi channels.
unfortunately when the crash occurs I cannot enter the router to read the logs, what i could do?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 28
lxbrador
Re: XR500, crash every 24 hour
Also have this problem with my XR500. Crashes once every 24 hours for a fortnight now, have to turn off and turn on to get it working again.
Firmware V2.3.2.120
Tried to use the buttons to turn WiFi off on the router but it’s completely unresponsive and won’t load the router admin page at all whether it’s on via or Ethernet.
Done a complete pin hole reset last week and still having this issue daily. What’s gone wrong I don’t have a clue?
Message 2 of 28
Guru
What modem/gateway is it connected to?
Message 3 of 28
lxbrador
It’s connected to a Virgin Media Superhub 4. Wasnt an issue until like 2-3 weeks ago
Just stops responding, drops wifi first then locks up
Message 4 of 28
LightManeye
Im connecte to HUAWEI ONT and the connection is Vodafone fiber (italy).
Message 5 of 28
Netduma-Liam
NetDuma Partner
@lxbrador Did any changes to the environment or network occurs prior to this issue randomly occuring? Did you factory reset your XR500 after upgrading to the latest beta firmware? Are you getting any error messages in the interface prior to the disconnection occuring?
@LightManeye Are you seeing any error messages in the interface prior to the disconnection occuring? After changing the DHCP range, did you then reserve IPs for your devices within the .2 to .50 range? That's the important bit.
Message 6 of 28
LightManeye
I have changed DHCP, but the problem comes back on time..
I can't see any error in log, because the modem reboot after 2/3 minutes after the cresh...
Message 7 of 28
Netduma-Fraser
NetDuma Partner
@LightManeye, just to clarify, when you're referring to the modem do you mean the modem the XR connects to reboots on its own or the XR reboots on its own after crashing?
Message 8 of 28
LightManeye
XR reboot after 2/3 minute after the crash.
We notice the problem because the WIFI drop down completely....SSID are visible but we cannot access anymore.
Message 9 of 28
Guru
Is the XR router connected to this ISP router or dirrectly to the ISP ONT?
If you have the Virgin Media Superhub 4 this already has wifi and router built in. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
Message 10 of 28
Netduma-Fraser
NetDuma Partner
How do you have the XR connected to power, through an extender or direct to a wall outlet? Are you using the power adapter the router came with or another? If you're using the same one do you have another you can try with?
Message 11 of 28
LightManeye
Couple of options,
The XR is connected to ISP ONT, we don't have any other wifi or HUB connected.
FIBER => ONT (huawei) => XR500
Message 12 of 28
LightManeye
The router is connected with the original adapter, i don't have any other. adapter to use with XR.
The router is not connected direct on the wall but i have an extender....is the same that i had since I bought the router .
Message 13 of 28
Netduma-Fraser
NetDuma Partner
Try it directly to the wall outlet, if more things have been plugged into the extender for example it may not be getting the power it needs
Message 14 of 28
LightManeye
Nothin reboot again and again...now i have saved a log before crash :
This seems to be strange:
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:42:38
entire logs:
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:43:22
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:43:22
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:43:19
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:43:19
[admin login] from source 10.0.0.71, Wednesday, November 03, 2021 15:42:46
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:42:40
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:42:38
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:41:32
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:41:32
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:41:30
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:41:30
[DoS Attack: RST Scan] from source: 217.160.0.67, port 80, Wednesday, November 03, 2021 15:41:15
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:40:50
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:40:50
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:40:48
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:40:48
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:39:15
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:39:15
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:39:13
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:39:13
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:38:32
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:38:32
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:37:35
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:37:35
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:37:05
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:37:05
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:37:02
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:37:02
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:36:14
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:36:14
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:36:12
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:36:12
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:36:12
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:36:12
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:36:10
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:36:10
[DoS Attack: RST Scan] from source: 5.9.227.33, port 80, Wednesday, November 03, 2021 15:35:16
[DoS Attack: RST Scan] from source: 5.9.227.33, port 80, Wednesday, November 03, 2021 15:34:30
[DoS Attack: RST Scan] from source: 5.9.227.33, port 80, Wednesday, November 03, 2021 15:34:21
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:33:05
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:33:05
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:33:05
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:33:03
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:33:03
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:29:41
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:29:41
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:29:39
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:29:39
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Wednesday, November 03, 2021 15:29:05
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Wednesday, November 03, 2021 15:29:05
[DoS Attack: RST Scan] from source: 217.160.0.67, port 65372, Wednesday, November 03, 2021 15:29:05
[DumaOS] process '/usr/bin/dpiclass' died restart:true, Wednesday, November 03, 2021 15:29:03
[DumaOS] recovering state com.netdumasoftware.dpiclass, Wednesday, November 03, 2021 15:29:03
[DumaOS] DHCP lease change., Wednesday, November 03, 2021 15:27:08
[DumaOS] DHCP new event., Wednesday, November 03, 2021 15:27:08
[DHCP IP: 10.0.0.72] to MAC address 50:02:91:62:52:a3, Wednesday, November 03, 2021 15:27:08
[DumaOS] DHCP new lease allocated., Wednesday, November 03, 2021 15:27:07
[DumaOS] DHCP new event., Wednesday, November 03, 2021 15:27:07
[DHCP IP: 10.0.0.72] to MAC address 50:02:91:62:52:a3, Wednesday, November 03, 2021 15:27:07
[DumaOS] DHCP new lease allocated., Wednesday, November 03, 2021 15:26:32
[DumaOS] DHCP new event., Wednesday, November 03, 2021 15:26:32
[DHCP IP: 10.0.0.68] to MAC address cc:50:e3:e5:27:ae, Wednesday, November 03, 2021 15:26:32
[DoS Attack: SYN/ACK Scan] from source: 51.81.135.223, port 80, Wednesday, November 03, 2021 15:25:23
Message 15 of 28
Netduma-Fraser
NetDuma Partner
DPI is for things like Traffic Prioritization so I don't think that would be causing a crash. It seems to be renewing the WAN IP and it's a local IP - you said you were connected to an ONT, does it have an interface you can access to give the XR a static/reserved IP?
Message 16 of 28
LightManeye
No, i cannot have access to the ONT... my router have this ip : 10.0.0.1
Message 17 of 28
Netduma-Fraser
NetDuma Partner
Ah yes thanks, you said you changed the DHCP range which is good - did you apply the reserved IPs as mentioned as it shouldn't be giving IPs within the DHCP range
Message 18 of 28
LightManeye
yes i have checked : Use Router as DHCP Server
and the Starting IP Address: is 10.0.0.50
ending is : 10.0.0.254
its ok?
Message 19 of 28
Netduma-Fraser
NetDuma Partner
That's fine yes but then you need to give devices reserved IPs between .2 and .49 - it's right under DHCP on the LAN Settings page
Message 20 of 28
LightManeye
I need to add all devices with a reserved IP ?
Message 21 of 28
Netduma-Fraser
NetDuma Partner
It would be best to yes as I think it should help with the issue
Message 22 of 28
Guru
If the XR changed it's IP address to 10.0.0.1 then this is a inidication that there maybe a router in front of the XR router using 192.168.1.1.
Couple of options,
Message 23 of 28
LightManeye
Hi i have set to all wifi devices with reservation ip address.....but some devices don't respect this reservation ? why ?
Message 24 of 28
Netduma-Fraser
NetDuma Partner
The devices likely need to be restarted and then they'll take the IP you gave them
Message 25 of 28
Discussion stats
  • 27 replies
  • 2702 views
  • 0 kudos
  • 7 in conversation
Announcements
Orbi WiFi 7
