- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 dead due to reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi my xr 500 router stopped working after rebooting from routerlogin.net web page, Tried all troubleshooting steps still same error,
Solid red light below power symbol, After pressing reset the red light goes off...Dont know how device gets dead just by reboot from web pages, Rquest you to help me to fix the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 dead due to reboot
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser @plemans after holding reset for 30 sec and releasing it the solid red light goes off completely, I have to push on off button to get solid red light glowing again ,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser had a talk to customer service, they have done trouble shooting steps and they say your not in warranty and this device is dead and cannot be repaired.... i am ready to pay out of warranty charges but they are denying completely, device cannot be repaired
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you try the tftp or nmrpflash?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you reboot the router does the power button start flashing orange? That may be why the TFTP isn't working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No the orange light stands still, blinks once after 10 seconds and still , if reset pressed for 30 sec then the organs light goes off completely till I press power on /off button
- Mark as New
- Bookmark
- Subscribe
- Permalink
With the router plugged in and powered on, press the reset button for 30 seconds. While still holding down the button, unplug the router from power for 30 seconds.With the reset button still held down, plug in the power back hold for another 30 seconds. Then lot go, wait 2 minutes and see if it works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If that doesn't work, try the nmrpflash I linked to earlier. It sometimes works when tftp doesn't.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you've tried everything and can't recover the router, the router is probably bad and needs replaceing. You'll need to contact NG support and see what your options are: https://my.netgear.com/support/contact.aspx
