- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 devices bounce between offline / online
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has anyone encountered my issue and do they have a resolution or recommendation? I have a couple devices that bounce between offline and online status and I can not get them to remai stable or explain why.
Device #1 - Printer wireless, 2.4GHz, bounces offline online in device manager, more off than online. Tried dynamic and static IP setting, no change. Printer is EPSON WF3540. Printer itself on it's own touchscreen always shows it is connected to wireless metwork. It will print just fine with print command.
Device #2 - Hardwired switch, Netgear SX10. In device manager devices boucnes between states every minute or so. All devices attached to switch remain showing as always online, no apparent loss in connectivity observed.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 devices bounce between offline / online
As someone who manages networks for a living this is a TERRIBLE design. If the device is powered on and connected to the network, it should not show as offline. No network monitoring systems reports it this way. If my system at work did this I would be getting notified 24/7 by false alerts. Please FIX this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you seeing this issue your self? Ya agree, nothing connected to the router should show as off line when connected, or even if no data is flowing.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, this is not true that it will show back up as active. I have an ArloQ wifi camera that is showing offline, I can connect to it and watch live video for over 10 minutes and it still is showing offline.
Right now it looks like anything attached to my EX7500 and not directly to the XR500 is showing offline even though I can ping several of them by name and even started a video stream using netflix. Still showing offline. I have updated the firmware on both devices. On the XR500 I have it broadcasting just one SID but the EX7500 I have broadcasting a name for the 2.4 and one for the 5 just to see what I am connecting too. I am still mapping the house for dead spots so I want to see what I am connected too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the feedback - it's very rare for a device to be completely idle (but connected), so we don't ever really hear of this issue. But it appears to have happened here, so we will look to tighten it more in the future.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am seeing this issue right now. I have multiple devices offline including devices currently on the internet. As I mentioned in my other post, this might be a problem with the EX7500. All of the devices that show offline including my ArloQ and Ring doorbell are connected to the extender.
Edit: my Freenas server is showing offline and it is connected to the router via a 2nd 8 port switch. It has a hardcoded IP address and it pinging.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you devices show as if you take out the EX7500 and turn it OFF?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been able to replicate using my phone that if I connect directly to the router, my phone shows up as active. If I switch to the extender, it immediately goes to an offline status. I left it for several minutes and it stayed offline. I was able to repeat this multiple times to confirm the results. As soon as I reconnect to the router directly it will go back online.
