- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 dropping lan connection on ethernet port 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has anyone had any issues with the router dropping connection specifically on lan port 2? My current version of DumaOS is V2.3.2.56, and only a reboot fixes the port 2 connection. I have changed out the cable, done a factory reset, and I have reflashed the OS image, but after a while the port would go dark, and wouldn't wakeup until a router restart. Currently I have moved the Roku over to port 3. Am I looking at a buggy OS version, or is it an indicator of an imminent hardware failure as the warranty is nearing expiration?
Also worth mentioning, the port leds on router and numbers labeled on the back of it, don't correspond with port numbers withing DumaOS. Port 1 is show as 4, 2 as 3, 3 as 2, and 4 as 1. I think that this particular port numbering in DumaOS is a bug, but none of the less it is really annoying from a $300 router.
Anyway, would appreciate anyone answering back to these concerns. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 dropping lan connection on ethernet port 2
Just to clarify, the lan ports don't match up with physical numbering under Device Manager's table view. Looks correct under Statistics menu.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe that the incorrect port numbers was a known problem with early units. Newly manufacturered units don't have this problem.
As for why port 2 isn't working, it sounds like a hardware issue. I've never come across just one port suddenly not working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been observing it a bit more. Moved the Roku back to port 2, and it hasn't dropped once all day yesterday, even had the xbox on that port for a few hours without issues . I'll keep a closer eye on it since I still have until June for warranty, but it hasn't been cosistently dropping day in and day out yet to confirm anything.
As for Device Manager misrepresenting port numbers, since it is an early unit issue, should I just live with it or open an RMA case?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Up to you... Since you've got one port that's not working, it might be worth RMA'ing.
