× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Reply
Highlighted
NetDuma Partner
Re: XR500 drops internet
Sent you a PM with firmware
Message 551 of 1,017
Highlighted
Tutor
Thanks. Updated and fingers crossed for interruption free internet.
Message 552 of 1,017
Highlighted
NetDuma Partner
For those with an Xbox that are having the issue please read the following carefully:
Go to the Store and install the Xbox Insider Hub app.
Launch the app and accept the terms of use.
A new option will be displayed when you bring up the Power Menu by pressing and holding the Xbox button on a controller: ‘Report a problem’. Selecting the ‘Report a problem’ button will snap logs and launch the Xbox Insider Hub into a bug reporting flow. Within the app select ‘Add new problem’, then under Categories select ‘System and settings’, then ‘Network Settings and Issues’. Then type in a description and details and then submit the bug. Once that’s done, provide the gamertag that was signed in so I can provide it to the Xbox team member to pull the bug and logs.
Important: Make sure that the bug is filed shortly after the issue occurs and without the console being rebooted so that the networking logs are still present. Will need to know what the you did and when to get the console back on the network so they can line that up with the logs to get a clearer picture.
Message 553 of 1,017
Highlighted
Just factory reset and installed the firmware update and still having the same issue as before. internet works, then disconnects from the internet. internal network and wifi works fine, but anything coming in from the wan stops working. i have no xbox or ps4 plugged in while i am doing these tests.
It's very annoying, should i return this and exchange it with a new unit?
 -Marc
Model: XR500| Nighthawk Pro Gaming Router
Message 554 of 1,017
Highlighted
NetDuma Partner
Hi Marc, do you have anything that does automatic updates? If so turn them off and see if that resolves it. Have you also confirmed you don't see this when bypassing the router?
Message 555 of 1,017
Highlighted
I don't have anything else connected to it that does auto updates.
And yes I don't see this issue with other routers. I am forced to use my r7000 again and the internet has been solid everytime i use it. When i plug back in the rx500 the internet is up, then down, then up, then down. While it's down i plug in the r7000 again and the internet is up and stays up.
 -Marc
Message 556 of 1,017
Highlighted
NetDuma Partner
Okay thats strange, you don't seem to have the causes that others did. Is there anything you notice when it happens every time? Such as heavy usage or anything like that?
Message 557 of 1,017
Highlighted
Luminary
I was wondering my net is still cutting in and out on this router I do have other routers I have used and use currently . I did notice a ton of lease changes happening.
[DumaOS] DHCP lease change., Thursday, November 01, 2018 18:08:37
[DumaOS] DHCP new event., Thursday, November 01, 2018 18:08:37
[DumaOS] DHCP lease change., Thursday, November 01, 2018 17:56:38
[DumaOS] DHCP new event., Thursday, November 01, 2018 17:56:38
[DumaOS] DHCP lease change., Thursday, November 01, 2018 17:56:37
[DumaOS] DHCP new event., Thursday, November 01, 2018 17:56:37
[DumaOS] DHCP lease change., Thursday, November 01, 2018 17:56:36
[DumaOS] DHCP new event., Thursday, November 01, 2018 17:56:36
[DumaOS] DHCP lease change., Thursday, November 01, 2018 17:56:35
[DumaOS] DHCP new event., Thursday, November 01, 2018 17:56:35
[DumaOS] DHCP lease change., Thursday, November 01, 2018 17:34:43
[DumaOS] DHCP new event., Thursday, November 01, 2018 17:34:43
[DumaOS] DHCP lease change., Thursday, November 01, 2018 17:34:42
[DumaOS] DHCP new event., Thursday, November 01, 2018 17:34:42
[DumaOS] DHCP lease change., Thursday, November 01, 2018 17:34:41
[DumaOS] DHCP new event., Thursday, November 01, 2018 17:34:41
I have a full log of it happening every 20 mins or so
Message 558 of 1,017
Highlighted
Guide
I haven't had a drop since 10/18 when I was sent the beta firmware. So far, so good. ooc - what was the problem that this fixed or rather, potentially fixed?
Message 559 of 1,017
Highlighted
Apprentice
Two days in a row (after about 24 hours-ish) I've had a strange issue with the router where it seems to have limited internet, for example, I can't access 192.168.1.1 without rebooting?
Currently on V2.3.2.32
Message 560 of 1,017
Highlighted
Prodigy
A Qualcomm issue with drivers, more than that I would not know and doubt Qualcomm would tell.
Message 561 of 1,017
Highlighted
Guru
Qualcomm strikes again. Smiley Mad
My Setup (Cable 900Mbps/50Mbps)>CM1100>Orbi RBK50 v2.5.1.16 and Orbi RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK852, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 562 of 1,017
Highlighted
Is there a Beta version addressing this issue after V2.3.2.32 went live?  I am having a ~1 / day disconnect from internet access.  The wireless connection doesn't drop, just actual internet access.  No issues direct to modem, no modem cycling, levels check out as well.  Router lights also do not indicate that connection has dropped.
Message 563 of 1,017
Highlighted
Guru
Can review this in mean time:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR700-WAN-Interface-Going-Up-Down-Peri...
Message 564 of 1,017
Highlighted
Modem info: Arris TM1602
Message 565 of 1,017
Highlighted
Also the thea you linked is re: the XR700, and the log doesn't indicate the ARP IPV6 issues mentioned there either.
Message 566 of 1,017
Highlighted
Guru
Was thinking of downgrading FW to see if anything changes what your seeing...
Message 567 of 1,017
Highlighted
Luminary
I was wondering if any one else on the beta has stuttering while trying to view webpages. I tend to get alot of lag spikes while using the beta msn.com will load super fast and then next time i launch msn.com it takes a good 8-20 seconds to load.
Message 568 of 1,017
Highlighted
NetDuma Partner
That sounds like it could be a problem with your PC - perhaps a cache issue.
Easiest way to check is to use other devices (e.g. a phone). If it's working fine on there then it's almost certainly something with the device.
If it's happening on everything. then it could be the actual website. So try some others and see how they play out!
Message 569 of 1,017
Highlighted
Luminary
It happens on my Iphone also and other websites . Its totally random when it happens
Message 570 of 1,017
Highlighted
Wonder if I should make a separate thread and see if @Netduma-Fraser has any thoughts
Message 571 of 1,017
Highlighted
Hello,
My wifi always reboot every morning, I will need to reconfigure it over and over again every morning.
Anyway to fix this?
Message 572 of 1,017
Highlighted
Guide
I have updated to the latest firmware 2.3.2.32 and loose internet connection which can vary from every few hours to every few days. Never had this with my Nighthawk R7000 which was flawless. Once I reboot the router it runs fine until next time. Wonder if it’s a firmware problem.
Message 573 of 1,017
Highlighted
NetDuma Partner
@Gingeg and @rougebaby - the next time you have a drop, could you check if your modem still has Internet? It might be an overall line issue, as I believe .32 solved almost all disconnection problems.
Also - are either you just experiencing this on an Xbox One? Or is this on other devices?
@Bobisbadat - perhaps make another thread - sounds like yours is quite specific so you won't want the conversation to be lost.
Message 574 of 1,017
Highlighted
Apprentice
I am sorry but this is a horrible canned response!
.32 is NOT FIXING disconnect issues! A lot of us still have wireless INTERNET access, so no, it is NOT the modem. LAN ports PERMANENTLY disconnect until a reboot of the XR500, NOT the modem.
I feel like support here, picks and chooses what to read. .32 DOES NOT fix disconnect issues!
Message 575 of 1,017
