- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 drops internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 drops internet
I got super frustrated and went outside for a bit, i came back in and went through the "setup process" though the router without a factory reset. It did restorre my internet, but the reason i rebooted the router in the first place is becasue im getting half the speeds i pay for. I plug ethernet in pc directly and i get the correct speeds. Im beyond frustrated with this router, the cons are starting to outweigh the pros. V2.3.2.32 is the firware im on, havent had any internet drops drops since i cut off instant on while using this firware, but today with my internet being completely down during "rush hour" for my home was unaceptable. Still not sure what to do about getting half speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you getting almost exactly half speeds? I remember seeing this before and it was to do with that user's modem. For some reason having it in Bridge mode halved his speeds.
Have you got yours in Bridge Mode / Modem Mode? If so, try putting it back to normal mode and seeing if speeds return to full.
And just in case I've misremembered, if you're already in normal mode, try setting it to Bridge Mode and see if that fixes it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
photos with and without router. I do not have a modem, fiber runs directly into my home from a junction box outside.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
To be honest, idk how to change from bridge to modem mode or vise versa. I let the setup process do it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If not give the XR500 the MAC address of the previous router you had. Sometimes ISP doesn't handle a new router well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
XR500 drops internet, XR500 drops connection wireless and wired
I had an IT company double check all my settings. SAME FIRGGIN PROBLEM. Drop Internet to Wireless and Wireless devices. Taking this piece of crap back to the store. What a waste of time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 drops internet, XR500 drops connection wireless and wired
- Mark as New
- Bookmark
- Subscribe
- Permalink
I called an IT professional who double checked my settings for IP conflicts and DCPH ranges. Short of reboots, spit, duck tape and rubber bands; what would you like me to try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey Boss, not trying to sound like an ass here. Ive use several routers with the same isp, 2 of them netgears. Im not about to use the mac adress of a $200 netgear for $400 netgear. Dont even have the router anywhere. Please just fix the router!!!!!!!!! Im one more internet drop away from ordering a t-link for christs sake.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Give devices Static IPs (incase DHCP lease renewal causes it)
Disable Instant On/Standby modes on consoles (as we've determined this to be directly related to the issue)
Use a switch behind the router to connect your devices to it
Use the beta firmware (just sent in a PM)
@BULL, thats a legitimate issue that can happen regardless of the router. Could you answer the QoS questions from my previous post please
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I had qos off yesterday when I had issues. Could have been bugged when it wouldn’t give me an internet connection. For the most part, it has worked fine with instant on turned off. Haven’t changed a single setting on sons ps4. Haven’t had too
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, yesterday I finally said enough is enough and went to Best Buy and purchased Nighthawk XR500. Go home, setup everything , played a couple of games and two hours later wireless went out. A couple minutes later the entire internet went down .. restarted the router and everything was back on. This morning did a same thing again.
There is definitely something going on with the dumaos ..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does firmware V2.3.2.40 have the hotfix apart of it also I did not see anything listed about connection on notes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
even on .40 Still can't stream any 4k content on sony devices with QoS on. I can't believe others are not having the same problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@EnticeTheMalice, very sorry to hear that, did you get a chance to try the recent update? We hope you'll consider the router again in future.
@Bulldaw6, cannot see the image at the moment as it needs to be moderated.
