- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 drops internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 drops internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know.
Enjoy.
@Dino74 wrote:
I was able to finally fix my issues by disabling manual dns servers and then selecting the reboot option on the pc dashboard for the router NOT USING THE PHYSICAL BUTTON NOR THE NIGHTHAWK MOBILE APP. The nighthawk app has done nothing but hurt my router it seems so I hope this helps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last FW update? I would try this first.
What browser are you using?
@Stevecook wrote:
I just updated mybrouter to new est firmware yesterday and having issues. My settings for auto ping host keeps resetting. I have to recheck it but still doesnt auto ping host. Internet keeps dropping out as well now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can see ping now. The auto ping box stays checked off. So it has to be a bug or issue with version 2.3.2.56
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
"If it works, don't fix it!"
@Stevecook wrote:
So after every firmware you have to factory reset router and reprogram everything. Also what advantage would I get going to 56 or disadvantage staying on the version I'm on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Happend for both wired and wireless devices?
@Sereph102889 wrote:
So I'm a new owner of the XR500 and I've been having intermittent rebooting and connection drop issues myself. Sometimes I dont see it happen for days, maybe even a week, and then it happens three times within 2 days. I've read through all of the info on this thread. My router is on the most up to date firmware version. What steps are most recommended to fix this issue? I've seen factory resets and all kind of things here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm about to try and sell this thing myself. Have had nothing but issues. A $300 router should just work. Wish they would just offer refunds at this point. I always owned and recommended Netgear routers. Unless they do something about the issues with this router it will be my last.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Smaugger wrote:I'm about to try and sell this thing myself. Have had nothing but issues. A $300 router should just work. Wish they would just offer refunds at this point. I always owned and recommended Netgear routers. Unless they do something about the issues with this router it will be my last.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Smaugger, is it this issue you're having or is there something else we can try to help with?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I currently just have my router connected to the modem via a Cat6 Ethernet cable and that's it. I didnt change any settings to bridge them together or anything. Is that recommended?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I came home last night from work and did a factory reset on the router. This time when it came time to start the router setup, the first thing it did was pop up a message saying: "changed router IP adress to xxx.xx.xx.xx" to avoid communication issues with ISP Modem". I then let it go through the entire setup process by itself, using automatic settings for everything. So far the network seems more crisp, I guess is how I could describe it. Anyways, I will post back if the issue continues. I actually don't think it was power-cycling anymore after something the router did night before last. I think it was losing all internet connection from the modem for some reason. Hopefully this resolves the issues.
