Discussion stats
  • 6 replies
  • 831 views
  • 0 kudos
  • 4 in conversation
Announcements
Reply
Highlighted
Follower
XR500 drops internet
My XR500 has been dropping Ethernet and the WiFi continues to work perfectly fine please help.
Message 1 of 7
Highlighted
NetDuma Partner
Re: XR500 drops internet
Do you have a console in Instant On/Standby mode? If so disable that and turn them off fully after use. We've found it can cause issues with other devices and are looking into it.
Message 2 of 7
Highlighted
Guru
What FW is currently loaded?
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.15.32(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 3 of 7
Highlighted
You should be able to log into your modem by goint to address 192.168.100.1 and logging in with admin and password for the password.
I would check the signal levels and google what they should be for your ISP.  There might be a signal issue with the modem.
Message 4 of 7
Highlighted
Guru
Any updates or progress on this?
Message 5 of 7
Highlighted
Wondering this myself. Just set this router up yesterday and had this happen first thing this morning. I am leaning on returning this router as I dont believe it will be fixed due to being an known issue for so long at this point. I watch tv through my xbox and with the console in energy saving mode it wont auto boot into tv mode.
Message 6 of 7
Highlighted
Guru
How is the xbox connected to the XR router? Wireless or wired?
You'll need to talk with MS support about the consoles modes and how to configure them.
Message 7 of 7
