- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 internet issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have just got a xr500 and installed it as directed to replace my default router from my fiber provider. All connected and working but unable to find the internet connection. I went through the install process and it failed so I set it up manually to get to the vlan settings. I made a new rule as my fiber provider said I needed to use 101. Still nothing. I have no idea what to do next. Please help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 internet issues
What is the Mfr and model# of the ISP modem/ONT?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
I would power OFF the ISP modem for 1 minute. Factory reset the XR router and power it off. Power ON the ISP modem and let it sync. Then power ON the XR router and walk thru the setup wizard again using a wired PC and a web browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try resetting your modem, then rebooting your XR500. Does it obtain an Internet connection after this?
If not, can you set your modem into bridge mode or modem mode and try again?
Finally, if that doesn't work, try factory resetting your XR500. Going through the initial setup will allow it to auto-detect your connection type
