- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500, many devices losing connection to internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I've had this router about 2 months now and it has been doing this since initial setup. My home network has many internet connected devices, and intermittently they lose connection to the internet (these include wired, and wireless devices) . They can still be pinged, but will not connect to youtube, netflex, etc.
I called in to the help phone line yesterday and they helped me diagnose it a little further and we found that the device that was currently not working, if assigned a static ip, and placed in the DMZ, it would be able to connect to the internet. So, we suspect it's a port issue.
The temporary resolution was to assign all devices static IP addresses, then enable port forwarding manually for all the services, by device.
I am interested if anyone can shed some light on what may be causing the blockage of the ports, or if I may be approaching this incorrectly. I would much rather have UPnP and DHCP handle the ip addresses and port forwarding.
My home network consists of a modem only, to the XR500, which has an 8 port unmanaged switch wired to it, and an EX8000 setup as a mesh extender (wireless)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500, many devices losing connection to internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was having a similar issue after my ISP went down for maintenance to conduct an upgrade to the network. A few devices (Nest Thermostat - Nest App / ADT Security System - ADT Pulse App / Chamberlain Garage Door - myQ), both connected via LAN and via WiFi, would connect to the XR500 but wouldn't communicate with / connect to their system (confirmed after contacting Nest Tech Support and ADT).
I figured out that the IP Address (x2) of the DNS Server I was using was the issue (obtained via NameBench program almost five years ago). After changing the IP Address (x3) of the DNS Server in the XR500 (Internet Setup), I have NO ISSUES and all devices stay connected.
Try 'Manually" using these DNS Server Addresses - 1.1.1.1, 8.8.8.8, and 9.9.9.9 - and see if that helps. It may not work in your situation, but I know it solved my issues.
