- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 wont let modem set IP
- Mark as New
- Bookmark
- Subscribe
- Permalink
All settings in the router are correctly set to let the ISP set the IP addresses dynamically
If I reboot the modem first, then the router, the local network goes up just fine but I get no internet.
If I reboot the router first, then the modem, I get internet but it's temporary and often flakey. My ISP tech support says that the router isn't accepting the ip changes dynamically for some reason and when the router trys to dictate the modem things don't work right.
Has anyone experiences this and if so, how did you fix it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 wont let modem set IP
@RPatrick wrote:
When the net goes out and I have to do the typical unplug and plug back in routine this odd thing is happening...
What is the manufacturers name and model number of the modem/optical network terminal you have in front of your XR500?
Are you sure it is not a combination device that includes a router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's not typical.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like the usual meaningless ISP tech support b*ll*cks.
Which ISP? Might help people to avoid it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes my modem is just a modem and not a combo router/modem
It's a standard spectrum unit supplied for gigabit service. I don't know the manufacturer.
The reason I have to reset frequently is because I lose internet service frequently. The network stays up but I lose online service, LED indicator goes red.
As I mentioned, if I reboot the modem first (as instructed by the ISP) then the XR500, the internet LED indicator remains red and I get no online service.
If I reboot the XR500 first, then the modem I get internet.
When speaking to the tech help at spectrum, they seem to indicate that this is a problem.
I suspect the reason I'm losing service a lot is when the ISP makes a change, the XR500 isn't dynamically following suit. Why not is the mystery. All the settings are correct, as far as I can tell.
ISP tech help thought It might be a bad WAN cable. I've tried 3. No change in this behavior.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RPatrick wrote:
Answers to the questions.
It's a standard spectrum unit supplied for gigabit service. I don't know the manufacturer. I am sure it has a label.
If I reboot the XR500 first, then the modem I get internet. Certainly not the norm, but also not that unusual.
When speaking to the tech help at spectrum, they seem to indicate that this is a problem. Open to discussion.
When you reboot the modem, disconnect the coax for a few minutes then reconnect before you restore the power. This provides a reset for some of the internal circuitry. If you have access, you may have to start looking at the signal power levels activity logs on the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
