DJByrd's avatar
DJByrd
Follower
Apr 19, 2020
XR500
Can I connect my XR500 to my internet if I have DSL internet? If so could someone tell me how to do it. Please I’m struggling here.
  • plemans's avatar
    the XR500 is a router only. Not a dsl modem.
    so you'd first need a dsl modem.
    then you'd want that device in passthrough/modem only mode.
    And then you'd connect the xr500 to that.
    many dsl modems include an integrated router.  Its becoming rare to find just a dsl modem only.
    Again, you'd want the router portion of the dsl device disabled or you'd run into double nat issues.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      There shouldn't be much you need to change on the router, it should detect what is needed through the setup wizard, have you gone through the wizard?
