× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR700 DumaOS issue: how to pin again the "Guest status" windows in the Dashboard?
ovar0409
Initiate
Hi there,
I unpined the "Guest Status" view from the Dashboard and as expected it disappeared. But how do you make it visible again in the Dashboard? Stupid stuff, but I cannot see any menu or whatsoever to re-activate that specific view.....
Thanks
Message 1 of 3
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: XR700 DumaOS issue: how to pin again the "Guest status" windows in the Dashboard?
Go to the System Information page on the router, there you will see the Guest wireless panel and you can then re-pin it by clicking the pin icon.
Message 2 of 3
All Replies
Netduma-Fraser
NetDuma Partner
Message 2 of 3
ovar0409
Initiate
Thanks
Message 3 of 3
Discussion stats
  • 2 replies
  • 1128 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
