- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR700 - How to prioritize PC Games/ Nvidia Shield
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am a bit confused by the gaming option in the drop down menu as it only lists a very small selection of games. How do I prioritize games played from my PC (hard wired) and games from my Nvidia Shield (WiFi)?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Elite Dangerous is an unlisted game, but luckily it's quite easy to manually prioritize a game.
To prioritize manually:
On the QoS page, under Traffic Prioritization, choose ADD DEVICE. Select the device you're trying to play on and press next, then press Advanced. Now you need to look up online what ports your game needs. Enter the ports and press Done.
For Elite Dangerous, they suggest that you open UDP port 5100 and then specify that port from within the game. Here's Frontier's guide on how to do this: https://support.frontier.co.uk/kb/faq.php?id=344
Another option that might work is to go to Device Manager in DumaOS, select your computer, and change its device type to PlayStation or Xbox. For many games on PC, this allows them to be correctly prioritized.
Here's a guide on the whole process: http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR700 - How to prioritize PC Games/ Nvidia Shield
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah for some reason it isn't working as intended. Some games are recognized but others are not (elite dangerous for example). Not sure how I would go about manually prioritizing it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
9 | |
5 | |
2 | |
1 | |
1 |
