Reply
XR700 Issues & Absolutely Ridiculous Support
Kinematic9
Initiate
I wanted to give everyone an overview of the experience I have had with a 5 day old Netgear Nighthawk XR700. I've been a Netgear Nighthawk user for a while, an R7000 then an X4S after that. Fast foward to this past week, I decided to upgrade to the new XR700 just to have the newest along with my interest in DumaOS...
Hooked it up, did the firmware update, and set up my wireless network to match my previous settings. My wireless devices show up on the device manager, then suddenly no connectivity for any of them. My phone is trying to connect and giving me "Unable to get an IP address" errors". Nothing is connected short of a few hardwired devices. I tried rebooting, factory resetting...but to no avail. I tried another factory reset, changed the SSID and then individually connected and renamed each device in my home. This wasn't a quick process either, with numerous Nest cams and other annoying to re-name devices.
Everything is fine for a day or two, so I decide to log into the interface and turn off the 60Ghz wireless radio which is, honestly, pointless to be on at this point. WiFi radios reboot and guess what, same issue again, nothing connecting to it, IP address errors, unable to get new IP addresses.
I call support, but guess what, nobody is around at 7:30pm EST that can work on the XR700. They put me in a queue and tell me their 'advanced tech' is not available. 1 technician who works daytime only to service and support the most expensive residential router they sell? Okay. Call me back the next day, I am not even home. They ask me to call back, which I do, and guess what...THERE ARE NO PEOPLE WHO CAN SUPPORT THIS ROUTER. What a f*king joke.
I downgrade the firmware to the previous version (2nd firmware) and I am able to get connections back instantly, but now the log is filled with "[DumaOS] No wifi metadata for mac" errors every second to like 25 wifi devices. The interface is barely responsive if I can even log into it without erroring out. I am unable to reach this interface all night, and luckily get back into it today. Do an upgrade back through the interface, which by the way is still LAGGING like anything due to those mac errors, and go back to newest. Guess what, NO DEVICES ARE CONNECTING AGAIN.
Long story short, I downgraded again to the release firmware, and this is working fine.
If anyone out there is having any similar problems, the release firmware seems to be the most stable. So far this has been a nightmare and I am extremely disappointed in how Netgear handles this with absolutely TRASH SUPPORT. I want this router to be solid and feel confident that I can trust it into the future, but I am now 2 firmwares back to make this stable, and nobody can seem to help me.
If anyone has similar issues I'd be curious to hear and if there are any known fixes to these issues, happy to hear that too.
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 7
Netduma_Jack
NetDuma Partner
Re: XR700 Issues & Absolutely Ridiculous Support
Hi there - Jack from  Netduma here. Sorry to hear you have had a rough time.
On the '"[DumaOS] No wifi metadata for mac"  - we have fixed this in the latest version (1.0.1.8). But I appreciate this version was not stable for you. There's a newer version of this firmware in the works which will hopefully be rolled out soon.
Let me know if there's anything else I can help with from the Netduma side of things.
Message 2 of 7
ALO4Q1
Initiate
same problem here this thing just refuse to stay online it just happen out of no where it comes and go and nothing get it going restart ,reset same thing nothing can connect this is the wrose nightmare routher i ever own had netgear for ever but this have being the wrose. sorry for my english but im sure my point is clear
Model: XR700|Nighthawk Pro Gaming Router
Message 3 of 7
Guru
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 4 of 7
Netduma_Alex
NetDuma Partner
I'm sorry you're having so many problems with the router. Have you tried downgrading to the release firmware as the original poster did to see if that fixes your issues? https://kb.netgear.com/000060213/XR700-Firmware-Version-1-0-0-20
Message 5 of 7
Kinematic9
Initiate
Alex, do you know of any progress with future firmware updates? I am afraid to upgrade past the release firmware which these days is absolutely ridiculous for security purposes. I know this isn't your fault and you are with Netduma, but I see no progress with any firmware and nothing to make it seem like these issues have been fixed. Do you know of any big updates coming soon?
Message 6 of 7
Netduma_Alex
NetDuma Partner
I know that there's a beta version of an XR700 firmware update being tested, it's pinned to the forums. I also know that we're working on updates from our end, but I can't tell you when they'll be out.
Message 7 of 7
Discussion stats
  • 6 replies
  • 2012 views
  • 3 kudos
  • 5 in conversation
Announcements
