- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR700 Keeps Kicking Offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the XR700 Router with the CM1000 Cable Modem.
Every time i try and play on Xbox live even just sitting in a party chat i keep getting kicked offline every few minutes. I have tried to factory reset the router, I have manually upgraded the firmware, downgraded the firmware, and factory reset again to the latest firmware. I do not get kicked offline from anything else. I have set a static IP for the xbox as well. I have also been reading a lot of people having issues with this router when playing on PSN and XBOX. The primary reason why i purchesed this $500 router was to use DumasOS.
I have used different cables from Cat5e to Cat7, with different ports as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR700 Keeps Kicking Offline
I have the same modem and had the same problem. I went to WAN setup and added xboxs ip , then checked only the 2nd and 4th box. then went to advanced settings to UPnP and disabled it. added the xboxs static ip in LAN setup and it hasnt happened again on the new FW. oh yeah, I also port fowarded the ports used for cod bo4 on router[3074-3075]
- Mark as New
- Bookmark
- Subscribe
- Permalink
yeah i have all ports forwarded as well. And i think i figured out the issue for me. Had to disable IPv6. For some reason the router cannot handle IPv6 for consoles it seems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW are you using?
Other users have expressed that downgrading to v20 seems to help with there disconnects...I would give this a try. Factory reset after applying the FW file and setup from scratch. I would reboot the modem as well during this process.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have native IPv6 from your ISP, if you don't i can be disabled.
If you do, and you thing that is a problem in the FW, I would file a support ticket here:
- Mark as New
- Bookmark
- Subscribe
- Permalink
you really need ivp6 if you can, try what I did first [ a couple replys back] and see if that works so you can have ping ass.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just to inform everyone; I've read somewhere that the XR500 & XR700 are kicking Xbox users offline. Netgear & MS are working on a fix but the current solution is to TURN OFF 'Instant On' in the Xbox Settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply, My Xbox is and has always had Instan On turned off. The router has and issue with MS IPv6, somehow it is incompatible in some form or another. The IPv6 keeps getting disconnected, and i do not know if it is Netgear's end, Microsoft's end, or both.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Curious; is this problem completely non-existent with IPv6 disabled? Or is it less frequent?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not sure if it's related, but it might be of course. Simplest way of finding out is to disable IPv6 and leave instant mode on. Then see if you get any more drop outs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI, IPv6 is not required for xbox or game play on xbox one. It's is a nice feature to have if your ISP natively supports it and the router is configured correctly to take advanage of it. You don't have to have it for xbox gaming. My ISP doesn't support it as of yet so I always keep it disabled. One day I we might see it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would do this, connect the xbox one directly to the ISP modem with out the router being online. The CM modem should auto pass thru any IPv6 to the xbox. You'll need to ensure the xbox is connected and configured correctly. It should seen IPv6.
Play some games. Do you see same problems with this configuration as well? If not, then there maybe an issue between the CM modem and the router/FW when using IPv6.
@IJayJayI wrote:
Yes that is true, IPv6 is not a requirement but it's suppose to run better since it is highly recommend even by Microsoft. I feel like I lag more on IPv4 than IPv6 (except now, with this whole issue) trying to do much more testing to make it to where I can play smoothly with IPv6. It's native to my ISP so I'd like to utilize it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
