- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
XR700 Keeps Kicking Offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR700 Keeps Kicking Offline
no you dont have to have ipv6 enabled to have a smooth gaming experence.. I have Xbox1 . go to there web site and you can see a list of reasons to have that enabled , according to xbox live if you want the BEST gaming experience , enable it lol
- Mark as New
- Bookmark
- Subscribe
- Permalink
a lot of us with the xr700 went through the same thing, if your running the new fw get a 10gtek plug or roll fw back to ...20 version. the new fw isnt stable. in my case netgear gave me a newer beta fw and that didnt work. I just bought the 10gtek and no problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I spent $500 plus tax on this router. Netgear needs to fix this. Even on IPv4 I get serious lag spikes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had one single devices and different devices connected to the router to test each device with all these variations. Same issue persists.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
im just saying me and a least 3 other users had the same problem and a user said it would fix the problem and it did. lol I bought it 2 weeks ago and newest FW runs perfect now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
yeah it sucks, but if you go back on posts you will see a link to the one for netgear on amazon.the post might be from pastor john
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you connect the Gtek to the modem or directly to the xbox? I just purchased the Gtek and wondering how youve got yours setup, becasue im wanting to upgrade the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, I have to say after some time, I got the new firmware to work (xbox included) and have been running it for over a week straight now. The only issues I'm having is the QoS doesn't seem to be working - I'm getting more bandwidth than assigned on all devices with IPv6 on and off.
I believe the reboot issues may be some setting that isn't/wasn't configured properly so I recommend a reset AFTER upgrading to the new firmware. IF you already have the new firmware; 1. downgrade to the old one 2. RESET 3. upgrade to the latest fw. DO NOT RESTORE any backup settings (it may have a misconfiguration that you may have overlooked). Reconfigure the entire router from scratch (with scrutinizing detail).
In my case; I found a Static Route was setup incorrectly, the NTP server was set to Netgear (default) but my other devices (ProSwitch GS110TP) weren't and IPv6 was misconfigured on the LAN. My router doesn't randomly disconnect anymore and my Xbox is fine too (even with it set to Instant On). Oh and I'm NOT connected to the 10g.
One thing to note; this router is VERY slow to have all services functioning after a reboot via hardware (pull plug) or sorftware (clicking reboot in admin settings). I timed it to 3 minutes so have patience because some of your settings may not function until it is fully back up.
And lastly; if you are using LAG (to a switch in my case); you must disconnect one ethernet cable PRIOR to rebooting system and keep it disconnected until after the system is fully back up. It will hang otherwise.
Hope this helps!
- Mark as New
- Bookmark
- Subscribe
- Permalink
your modem plugs into that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you! However, I have a Gigabit connection and my (wired) xbox was getting 230-500Mbps when I set it in QoS for 130Mbps.
SIDE NOTE: I have about 18+ devices (TVs, cellphones, smartwatches, etc) so I set my Wired & Wireless Xboxes to use 20% each of the anti-bufferbloat bandwidth (knowing that all these dedvices will never ALL be online at the same time but configuring the router as if they would).
BUT I believe this is resolved as well. I followed the speedguide for the XR700;
1. Turned off QoS (leaving the antibuffer bloat settings as they were)
2. Ran Speed Test on Xbox - same results
3. Turned off IPv6
4. Ran Speed Test on Xbox - lower download speeds (from 500Mbps to 80-130Mbps)
5. Turned on QoS (unticked box)
6. Ran Speed Test on Xbox (130Mbps-20%)
7. Turned back on IPv6 - lost connection to Internet and login access (tho all lights were on)
8. Pulled power cord for 30 sec -plugged back in
9. Verified QoS & IPv6 settings
10. Ran speed test on Xbox - Works Great!! Both Wired and Wireless Xboxes are in the 20% range of speed test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update Possible Solution!
So far Rick6922 has come with the only solution. Unfortunetlly Netgear themselves do not have a solution and the router is overall broken with the any of the newer firmware updates. Only the original firmware works unless they come out with an update.
So far the only solution is to use the SPF+ slot by purchasing the 10Gtek to convert the slot into an ethernet port.
With this you can have do anything you want in the router with no problems. I've been using it for a week now and so far no issues.
Unfortnetlly it's $100 extra for the part, where honestly netgear needs to fix because a $500 router should work perfectly out of the box with all updates. I understand some of the firmwares could have glitches but it's astonishing that all the firmwares updates have simply made the router worse.
Here is the amazon link of the adapter i purchased. I will update yall if anything changes or it stops working etc. This is, so far, the only semi solution if you want to use the latest firmware. (Your Internet Modem plugs into this and you need to reset router, update router's firmware, then setup router with the 10G port)
https://www.amazon.com/gp/product/B01KFBFL16/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far the newest firmware+GTek10G worked well at first.
It works well with the IPv6 now with Xbox. Now having another major issue with the new firmware.
I have to constantly restart the router daily. It keeps loosing internet connection until I restart it. It's quite frustrating. (Can Netgear please fix these issues?, Again a $500 router that doesn't work better than a $80 router)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would submit a support ticket to let NG know what your seeing with the new FW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
1:) Xbox connection dropping when IPv6 enabled. (GTek10G fixed that.
2:) all firmwares above the first one dropped internet for all devices once a day where I had to reset the router daily.
Original firmware was the only working one with GTek10G.
Now with newest version I only have to restart daily now. I'll test out each firmware for a week to see if it is consistent and will update yall after my trials.
- « Previous
- 1
- 2
- Next »
