- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR700 Periodic WAN disconnects (still) on latest v1.0.1.8
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR700 Periodic WAN disconnects (still) on latest v1.0.1.8
Sorry, correct it.
You can try disable IPv6 and reboot router, then check network disconnect issue.
Win10 usually choose IPv6 internet prior to IPv4.
- Mark as New
- Bookmark
- Subscribe
- Permalink
IPv6 is diasbled. As stated earlier in thread. Issue remains.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some say that down grading to v1.0.0.20 resolves this issue:
You might try this and see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried IPv6, that didn't work for me. I rolled back to the older firmware and that resolved the issue on the RMA router I received.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know. Hope this will help others until NG fixes the latest versions of FW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Furrye38. That is exactly what I am running right now. Unit functions well with v1.0.0.20. This is also stated in the orginal post at start of this thread. No contact from NG at this time. Customer care response quality and time is a poor experience so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear support is working with my at the moment, and I have some testing to do later tonight. Hopefully the fix will work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ExpLiciTSainT . I am interested to know what they are having you test! Maybe send in message if you do not want to post in this thread. I am more than willing test things and give input to support team.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had to accept a EULA and I admit I didn't read it very well. I don't think there was an NDA, but it's basically a beta firmware. I just uploaded it and I am testing it now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The beta firmware failed to work. Rolling back to the .20 version. Seems good so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since beta FW does not work for you, my suggestion to you is to file a ticket to support team to check your case (without IPv6 disable), maybe arrange remote debugging or collect more debugging log to figure out what the issue is
- Mark as New
- Bookmark
- Subscribe
- Permalink
How many of you guys having WAN disconnects have Xbox attached to your XR700? How many of you have Xbox with Instant On feature turned on. It is possible that this issue is related to Xbox and the Instant On issue we saw previously on Nighawk Pro Gaming routers. If you have Xbox attached to your XR700 are you able to turn off the instant on feature or remove Xbox from equation to test if the issue occurs. If removing the xbox form network or turning off Instant On feature fixes then issue could be related to the Instant on feature causing a crash on XR700 internal switch causign all connections to disconnect every few minutes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have XBOX connected to router, but it is set for energy savings mode. The WAN disconnects are during usage...not overnight. Example, connection lost after 5mins, 7mins then 15mins, then 60mins, then 65...etc random periods. When it drops it restarts in 3-5 secs later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far, the problem occurs on previous firmwares, but would go away after a couple of days (or at least be reduced). The latest firmware never got better. Rolling back to the 1.0.0.20 firmware completely solves the issue. I have multiple Xboxs, PS4s, Smart Switches, TVs, Audio visual receivers (AVRs), Smart lights, Cameras, and more. I've worked with Motorola to check the modem, Comcast to check the lines, replaced cables, and now even replaced the router. Only one single thing has improved it, changing the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Others are reporting success with reverting back to v20 FW as well:
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been in contact with Customer Care and have a ticket open. They have been responding to me daily. I just sent them an update on their beta firmware failing to work and waiting on a reply back. I'll continue working with them until they release a firmware that resolves the issue. I really like their router, so I am hoping they can figure out the problem. At least I can 100% repro this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good information and good to know NG is involved.
Keep us posted on how it goes. I'm sure they will get it fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ditto to ExpLiciTSainT comments on devices attached and repeatability of issue. Only one change has impact on my connectivity experience. Adding/stripping devices, IPv6 on/off, console connected/not connected...etc, etc. None of this changes outcome.... change firmware and it will work or not work subject to version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Quick update for those interested. Netgear support is now in contact wiht me. First step was to load a beta firmware and report back observations/situation.
Three major observations.....
1. Upgrade (load) of beta without erase/factory revert resulted in same unstable WAN operation. The full reset created a few tense moments. After firmware load and resetting I thought unit bricked itself. Lights would come on, but trying to access it via web page, wired or wireless was incredibly slow and unit would ever complete the built in startup sequence. Also it was in a permanent no WAN connection mode. Tried powering off (let sit 15mins), restart, reset button, disconnect all devices, etc...nothing changed unresponsiveness and then it wakes up an says ok lets play normally - this was after 90mins of cursing at unit. Since then see results reported in #2 and #3.
2. WAN reported one disconnect/restart 3mins after powerup. However it has not dropped again in the subsequent 12hr period....previously it would repeatedly drop/restart inside 5-40mins timeframe. To be fair this first one could have been me reseting cable modem at same time. Will monitor through day/week.
3. LAN1/2 in default setup and being used aggregate mode. NG switch attached to it. Uptime monitors shows restarts in each link at various points, typically hours of run time before one will restart. They do not drop together, each one is showing different uptime time. Do not recall this being noted before - possible new issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the update. Please continue to share anything you find directly with NETGEAR support and they will hopefully be able to get to the bottom of this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sharing here what was shared with netgear on my case.
5 days on since system reset with beta firmware results show signs of light for future releases on WAN stabilityissue.
WAN remains up - very close to system uptime value
LAN1/LAN2uptime counters restarting at various points - setup to run as LAG1 to netgear switch. Switch shows no lost packets.
Ignore LAN5 uptime as this is device that has a preset on/off time, so it is valid to see low value there.
Port | Status | Up Time |
WAN | 1000M/Full | 05:13:51:39 |
SFP+ | Link Down | 00:00:00 |
LAN 1 | 1000M/Full | 05:22:22 |
LAN 2 | 1000M/Full | 01:21:30:09 |
LAN 3 | Link Down | 00:00:00 |
LAN 4 | 1000M/Full | 05:13:55:25 |
LAN 5 | 1000M/Full | 02:27:49 |
LAN 6 | Link Down | 00:00:00 |
WLAN b/g/n | Link Down | 00:00:00 |
WLAN a/n/ac | 1733M | 05:11:32:46 |
WLAN ad | Link down | 00:00:00 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
