×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
XR700 Plex update
gfhartzell
Star
XR700 Plex update
When should we expect a firmware update for the PLEX server?
RAXE500
XR700
RAX120
Message 1 of 20
Netduma-Liam
NetDuma Partner
Re: XR700 Plex update
Unfortunately that's not something I can tell you as a member of the Netduma team, we don't have any input on the NETGEAR features like the USB functionalities. There is new firmware in the works and we're nearing it's release, but unfortunately I can't confirm whether there will be any upgrades/updates to Plex.
Message 2 of 20
gfhartzell
Star
My Netgear Nightawk XR700 requires an update to Plex Server version for live tv
My Netgear Nightawk XR700 requires an update to Plex Server version for live tv.
Current Version 1.22.3.4392 Minimum Required is 1.24.4 or higher.
when will there be a firmware update for the plex server?
Thank you for your assistance.
RAXE500
XR700
RAX120
Message 3 of 20
gfhartzell
Star
Re: My Netgear Nightawk XR700 requires an update to Plex Server version for live tv
ps
Current Plex version: 1.22.3.4392-d7c624def  Apr 19, 2021
Your Plex Media Server version is up to date.
RAXE500
XR700
RAX120
Message 4 of 20
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 20
gfhartzell
Star
Thank you for the move request
This is a recurring issue over the years with no obvious path to even contact Netgear
For the required update unfortunately
RAXE500
XR700
RAX120
Message 6 of 20
gfhartzell
Star
now i am getting an error message that server version Required is 1.24.4 or higher for live TV.
any way to nudge netgear? or how to contact someone at netgear about this recurring issue?
last update was  version 1.22.3.4392 dated April 19, 2021
Thank you
gary
RAXE500
XR700
RAX120
Message 7 of 20
I don't now where you tried before, but as long as you to ask in the right place the path for support for devices with DumaOS, is usually short and rapid.
The DumaOS team has no reason to look out for every message posted in the wrong place. There are just too many messages to keep up.
Post in this section and you rarely have to wait long. Of course, lobbing in a request late on Friday, just before the weekend, isn't the best timing if you want instant replies.
This page  might also be useful:
DumaOS Firmware Progress : NETDUMA
Message 8 of 20
Guru
You might reach out to NG support.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 9 of 20
Netduma-Fraser
NetDuma Partner
I'd recommend making a ticket with Netgear directly https://my.netgear.com/support/contact.aspx meanwhile I'll see if we can ask someone at Netgear to see if they can get this sorted
Message 10 of 20
gfhartzell
Star
I placed a ticket after several attempts going in circles I finally was able to get a ticket by leaving out my serial number.  hopefully one or both approaches will get a response,
thank you
Gary
RAXE500
XR700
RAX120
Message 11 of 20
ReallyStoked
Tutor
Gary,
I am having the same issue.  I take it this is a NetGear issue and not something Plex should be fixing?
Wayne
Message 12 of 20
Guru
Message 13 of 20
gfhartzell
Star
Netgear does the Plex updates through the firmware update process.
there is no other known  way to get it updated unless Netgear makes it available.
It has been well over a year since the last plex update.
please try to get a ticket with netgear.
latest from Netgear on September 24, 2022:
Hi Gary,
I hope you are doing well. This is to give you an update about your concern. I just would like to inform you that we have already contacted the Engineering Team for an update. They mentioned that there is no fixed time for the PLEX update to arrive.
RAXE500
XR700
RAX120
Message 14 of 20
gfhartzell
Star
Current PLex Media Server release 1.29.0.6244 is now available to everyone (plex released September 2022)
NETGEAR Support
XR700 Firmware Version 1.0.1.44
Was this article helpful? Yes No
Enhancements:
Updates Plex Media Server to v1.22.3 (plex released April 2021)
Security Fixes:
Fixes security vulnerability issues.
NETGEAR Support
XR700 Firmware Version 1.0.1.34
New Features and Enhancements:
Supports Plex media server version 1.19.5 (plex released July 2020)
Supports additional ISPs from Asia in the ISP profile list on Internet Setup page
Bug Fixes:
Fixes the SAMBA issue when the file size is greater than 2 GB.
Security Fixes:
XR700 Firmware Version 1.0.1.20
Supports Plex media server v1.18.0 (plex released October 2019)
Supports new certificates for https
Supports the ReadySHARE feature in AP mode
In the VLAN/Bridge settings, the ISP profile menu includes additional ISPs from Europe and Asia
Bug Fixes:
RAXE500
XR700
RAX120
Message 15 of 20
Netduma-Fraser
NetDuma Partner
I take it you haven't had any further correspondence with support about an update?
Message 16 of 20
gfhartzell
Star
Latest Response dated yesterday 10-8-2022
not sure what to make of it?
RAXE500
XR700
RAX120
Message 17 of 20
gfhartzell
Star
Since there is no ETA, we cannot provide an exact date for the new firmware. Hence, we suggest to close the case for the mean time and you will automatically receive updates if there is a new firmware if you're subscribed to receive updates from Netgear
RAXE500
XR700
RAX120
Message 18 of 20
Netduma-Fraser
NetDuma Partner
Although this is a purely Netgear feature, I'll talk to our team and see if we have found out any more information
Message 19 of 20
gfhartzell
Star
Thank you for trying
Gary
RAXE500
XR700
RAX120
Message 20 of 20
Top Contributors
Discussion stats
  • 19 replies
  • 1560 views
  • 7 kudos
  • 6 in conversation
Announcements
Orbi WiFi 6E
