- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR700 VPN Tunnelback issue on Mac
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same problem here on a XR700. Setting the VPN config in the router to forward all traffice doesn't work on Tunnelblick on MacOS. Yes, I updated my config. Selecting "Auto" and using that config works just find but doesn't forward all traffic like I want. OpenVPN on android works just fine. I know it's not a DNS issue. Interestingly, going to http://whatip.me/ does show me an IPv6, but no IPv4 address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR700 VPN Tunnelback issue on Mac
- Mark as New
- Bookmark
- Subscribe
- Permalink
回复: XR700 VPN Tunnelback issue on Mac
Hi, do youm means, mac connect to XR700 as an vpn client, and want to search the internet? you you select auto, maybe the country you live will affect this feature. You'd better to choose internet and home. Do you set IPv6 wan in XR700 or not?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're using openVPN server. while android openVPN client works but your macbook, might need to check whether config file IOT issue for your macOS (what's OS version?).
you may provide all related info to NTGR support team to fix your issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@thatmyles What type of setup are you running? Who is you ISP and what modem do you have connected to XR700? Also for the OpenVPN setup on Mac what error messages are you seeing on Tunnelblick logs? What is the MAC OS Version and Tunnelblick version you are running?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was experiencing the same issues, and I finally got it working.
First, I followed the instructions laid out here by user KevinSharku to change the parameters in the client.conf file:
And then copied the contents of the downloaded files from the router (including the edited client.conf file) to a new folder and changed the extension to a .tblk as instructed here:
https://kb.netgear.com/25389/Enabling-VPN-service-on-a-Nighthawk-router-using-a-MAC-OS-computer
- Mark as New
- Bookmark
- Subscribe
- Permalink
