Reply
Highlighted
XR700 WAN Interface Going Up/Down Periodically
Hello,
Just got a new XR700 today. I have found that the WAN interface is going down briefly and coming back up every 10-20 minutes or so. This did not happen previously with my XR500 while connected to the same CM600 modem.
I'm able to monitor this by going to Settings > Monitor > Statistics. I can see the WAN port has an uptime of less than 20 minutes while others have been up for a couple of hours. Furthermore, if I start some continuous pings for various domains, I see them drop packets when the uptime for the WAN port resets.
I have tried re-flashing the firmware after downloading it from the web site, I've done a factory reset of settings, and I've tried swapping the network cable for the one I used before with my XR500.
Is there any way this can be fixed with a firmware update? I'm really discouraged by thinking about having to replace it, seeing as it was difficult to find one in stock in the first place. Thanks for reading all of this.
Travis
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 22
Accepted Solutions
Highlighted
Re: XR700 WAN Interface Going Up/Down Periodically
I downgraded the firmware from 1.0.1.2 to 1.0.0.20 and did a factory reset. The WAN port has stayed up for over 2 hours now, so this is very promising. Disappointing to lose the Hybrid VPN, but I'd rather have a stable connection at this point.
Message 2 of 22
All Replies
Highlighted
Message 2 of 22
Highlighted
NetDuma Partner
Hi Travis, sorry to hear you're having this issue. Do you notice anything about your network activity when the WAN port drops? A heavy download, no internet usage at all etc? Likely something that can be fixed with an update but hard to tell until the cause can be diagnosed.
Message 3 of 22
Highlighted
Hi Fraser,
I don't think I was able to come up with any rhyme or reason for why the WAN connection would drop. It felt more like it was a matter of time rather than load. I could never seem to stay connected for more than 20 minutes, but the amount of time would vary. I could run speed tests, etc. and it would stay up for the duration of the test and afterwards. I could leave everything alone and still see the connection drop on the statistics page.
That said, downgrading to the previous firmware has apparently worked around the issue for now. This is looking like a firmware issue as opposed to a hardware one.
Thanks!
Travis
Message 4 of 22
Highlighted
I have not seen this issue.
Maybe Hard Reset the modem and or check the dBmV levels on your modem; they should be within -7 to +7 dBmV. It sounds more like a connection drop or communication issue with the modem. I have yet to see this happon sence beta testing this unit.
If You Got Em....I'll Chew Em!
Products: (MC227BL|VMS5140P|AAD1001|AC1001|RAX200|XR700|CM1100|CM1000|C7500|R7500|
Netgear & Arlo Beta Tester
Message 5 of 22
Highlighted
NetDuma Partner
Okay thanks for the update, when the next version is released please see if you experience it on that version
Message 6 of 22
Highlighted
I have a similiar issue. My internet has gone offline at least 3 times since starting using this router on Thursday. It hasn’t happened twice overnight where I have woke up to Internet Offline status and once while I was at work. WIFi still looks connected so you don’t realize until you try to use the internet. Then I check the status through the app. A reboot of the router gets a connection back, but only a matter of time before it goes offline again.
Message 7 of 22
Highlighted
NetDuma Partner
Thanks for letting us know this is happening to you too. If you have not done so already, please downgrade back a version to see if it fixes the problem: http://www.downloads.netgear.com/files/GDC/XR700/XR700-V1.0.0.20.zip
Message 8 of 22
Highlighted
So far so good. I downgraded the firmware last night, and I didn’t lose internet connection overnight for the first time since installing the router.
Message 9 of 22
Highlighted
I have found a fix for connecting dropped issue and it is link to ipv6. After many hours of review logs and connection testing I found there was bug within the firmware. I not 100% what it is as I not able to go in to code but it linked to ARP table.
As long as turn on ipv6 and make sure ipv6 DHCP on it will fix it the issue. After this no more connection dropping. I played two hours on wow and perfect.
Message 10 of 22
Highlighted
Apprentice
I had issues dropping connection too.  Looking in log I saw ARP lookup errors asscoiated with IPv6 addresses. Downgrading firmware as suggested here fixed my issue.  Did not have issue on XR500, had issues with XR700 on v1.0.1.2.  Going back to v1.0.0.20 fixed my issues.
Message 11 of 22
Highlighted
NetDuma Partner
Thanks all, I've forward this to a member of the XR700 team for them to have a look at. Hopefully they can identify the cause.
Message 12 of 22
Highlighted
Now it is happening on 1.0.0.20 firmware. So disappointed in the amount of money spent on this router and it works like crap. Can’t believe it was released like this.
Message 13 of 22
Highlighted
NetDuma Partner
Sorry to hear that StoneCold. Could you disable the 60GHz WiFi from Advanced Settings and see if that improves it please
Message 14 of 22
Highlighted
Apprentice
XR500 with exact same settings works without issue - hence suspect not ISP side issue.
Firmware version
XR500 V2.3.2.32
Observations between two firmware versions operating on XR700
On V1.0.0.20 WAN kept connection for greater than 2 days...ISP issue last night so it reset with valid cause.
On V1.0.1.2 WAN will drop every 5-12mins on average.  Very quick drop, 2-3sec interuption.
In both cases an erase settings option was used before loading firmware. Made no difference two times I have tried V1.0.1.2 firmware - same results shown as above.
Log shows nothing unsual before internet dropped message captured in log - note earliest entry is at bottom, most recent is at top..
Here is example of log with everyhting turned on to report (IP addresses partially x'd by me)
[DumaOS] Error parsing line in ARP table: 'fe80::280f:56b1:xxxx:xxxx dev br0 lladdr 2c:54:91:db:de:79 STALE', Wednesday, October
[Internet connected] IP address: 69.xx.xx.xx, Wednesday, October 31, 2018 21:16:02
[DumaOS] No wifi metadata for mac '6c:33:a9:xx:xx:xx', Wednesday, October 31, 2018 21:15:43
[DumaOS] No wifi metadata for mac '8c:3b:ad:xx:xx:xx', Wednesday, October 31, 2018 21:15:43
XR700 setup is very basic...
WAN = DHCP from provider
LAN = DHCP using default value / range; two devices set to fixed addresses.
GEO filter - no devices added
QOS = on with traffic, ABB @ 70%, DL = 135 UP = 12.3 (inside actual pf 150/15); 1 device added
Device BW sharing = equal to 9 devices (8%) favor 1 device = XB given (28%)
Wireless 2.4GHz off / 5GHz on / 60Ghz off
Device 9 hardwired; 1 on 5GHz
LAG dynamic enabled and active - connected to SX10 switch
IPv6 off
Media server enabled; Tivo support = on; iTunes = off
Readyshare all default - not USB device attached
Tivo support = off
Cloudbackup = off
Port Forwarding = default; no rules set
Port Triggering = default; no rules set
Dynamic DNS = off
VPN = off
Static routes = nothing set
Remote mgt = off
UPnP = on; 30/4
IPv6 disabled
VLAN = off
LED = blinking
PLEX = not downloaded
Something not right with unit / firmware at this time.
Notes for v1.0.0.20
Devices manager does not update / shows device state incorrectly
It is possible to have a device show as having two IP addresses..FYI XR500 can achieve this too and not resolve itself.
In traffic prioritization a device added will show wrong device type; consoles all show as XBOX even though is listed as playstation in device manager
Message 15 of 22
Highlighted
Maybe run a Debug Capture through http://routerlogin.net/debug.htm that way you have some more data to give to support.
Message 16 of 22
Highlighted
NetDuma Partner
I have given this to the team so hopefully they can figure out the cause/follow up with you. The debug capture would be very helpful as well, thanks for the suggestion slomp.
@Altsai
Message 17 of 22
Highlighted
Unfortunately disabling 60GHz did not work.
I even turned on IPv6 and still no go.
My connection lasted for a while but it went down this morning.
Message 18 of 22
Highlighted
Apprentice
XR700 WAN Interface Going Up/Down Periodically on V1.0.1.2
I have tried both v1.0.1.2 and v1.0.0.20 again.
V1.0.0.20 ran for 2 days no connection loss on LAN or WAN (as shown in stats)
V1.0.1.2 ran for less than 5 minutes before WAN dropped..reset and so the cycle begins
I believe I captured debug correctly.  Is safe to attach here or should submit direct to admin via another means.
Message 19 of 22
Highlighted
Maybe throw it up on a cloud service and send the link to @Netduma-Fraser , he should be able to forward it to the Dev team.
Message 20 of 22
Highlighted
I switched back to my old router on Friday and haven’t lost the connection once since. There is something definitely wrong with the XR700
Message 21 of 22
Highlighted
Luminary
Re: XR700 WAN Interface Going Up/Down Periodically on V1.0.1.2
provide all debugging log to NTGR admin to fix your issue
Message 22 of 22
Discussion stats
  • 21 replies
  • 4103 views
  • 3 kudos
  • 8 in conversation
Announcements
