bmguidry
Dec 03, 2019Tutor
XR700 and S8000 Set up settings
I am going to be setting up a XR700 with a S8000. Are there any specific settings I need to change for this to work properly or is it just plug and go? Set up will be Modem to XR700 to S8000.
The S8000 also has QoS I believe. It's recommended to use either the QoS features on the XR router or the S8000 switch however not at the same time.
Review this for optimal settings:
http://support.netduma.com/support/solutions/folders/16000090646
- bmguidryTutor
It will connect to a Pace 5286AC. I have a fiber ont. I have to use the Pace 5286AC as it controls my cable TV as well unfortunately.
Regarding modem router combo units, Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. <I believe you'll need to configure this option.
