- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR700 and Wi-Fi stops at 15-20mbit
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 300 mbit down and 150 mbit up
when I test via cable all is good, and test directly to fiber router all's is perfect
i set up the XR700 not even 1 year old and it tests Wi-Fi and says 300 down and 130 up so that is also good.
when I test the Wi-Fi after all setting is ready it says 15 and max 20 mbit down and gets crazy 190 up
i removed QoS and one time I got good result then it went back to max 20 mbit down
latest firmvare is on and I am about getting a hammer an hit the XR700 after 100 tests
also about to make factory reset
since I bought it I have had 24 mbit so I feel like it has learned that this is max but now fiber and 300 it got lazy
please help me you experts
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad to hear you managed to resolve the issue. I would recommend you take a look at our optimal settings guides. They will help you understand the router and how to use specific features. There are also ? icons on all panels that give you more information as well.
http://support.netduma.com/support/solutions/folders/16000090646
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR700 and Wi-Fi stops at 15-20mbit
The top left corner in QoS there is what down and up are maxed I thing my xr700 had made settings for previous setting
I have put hem both on 1000mbit so it rocks
Design bad from net gear to have so important issue hidden in that small menu
I was about to kill it
- Mark as New
- Bookmark
- Subscribe
- Permalink
