× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR700 disconnecting so often
XSlashDashX
Tutor
Hello. Just recently purchased this router and noticed that my PC that is hooked up to ethernet cable keeps getting disconnected every
5 or so minutes.
Current firmware version I have is XR700 V1.0.1.8
Same goes for Wifi. I can be on for a bit and will cut off.
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 6
Netduma-Fraser
NetDuma Partner
Re: XR700 disconnecting so often
So this is across ALL devices? Upgrade to the latest firmware version and see if that resolves your issues.
Message 2 of 6
XSlashDashX
Tutor
Isn't the firmware I posted the newest?
Message 3 of 6
Netduma-Fraser
NetDuma Partner
Ah yes, apologies! In that case I would recommend downgrading to this firmware: https://kb.netgear.com/000060213/XR700-Firmware-Version-1-0-0-20 as some people with issues similar to yours have found it doesn't occur on that firmware.
Message 4 of 6
XSlashDashX
Tutor
So far so good. Haven't used it much but played a few rounds of different games and no disconnect yet from downgrading to old firmware. Hoping the new version will have this bug fixed.
Message 5 of 6
Netduma-Fraser
NetDuma Partner
Great to hear that, keep us updated. Yes our teams are looking into it as we speak
Message 6 of 6
Discussion stats
  • 5 replies
  • 1405 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
