× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR700 router will not connect to internet!!!!!
dlsissoni
Follower
Trying to configure a brand new XR700 router from an iMac. Followed intructions to the TEE! When I go to routerlogin.net, it tells me that I have no internet connection and the internet light NEVER comes on!!!!!! Tried it in Safari and Chrome. Cleared history and cache six times. Restarted UBEE DVW32CB Time Warner modem and XR700 router seven times and reset modem twice to factory settings. Tried three different modem ports and two Cat 5 cables. Modem has green light on each port when connected. Mobile devices connect to router's wifi network but there is no internet connection there either!! Please help or should I return this expensive router???
Please help or should I return this router
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 3
Netduma-Fraser
NetDuma Partner
Re: XR700 router will not connect to internet!!!!!
Can you access the interface using the LAN IP of the router? If you can access it, manually go through the setup wizard, does it work then?
Message 2 of 3
Guru
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1900 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
