conkerick's avatar
May 19, 2021
XRM570 Wifi DHCP Issue
Hi, since I bought the XRM570 (XR500) I am having this issue:
From time to time, randomly, the router does not assign an IP address over WiFi. The devices indicate "could not assign or get an ip address".
When this problem happens, if you are connected to the WiFi there is no problem, but if you disconnect, you cannot reconnect. And if you were disconnected and you try to connect, you can't either.
The only solution is to power cycle the router (sometimes I have to power cycle multiple times).
The connection via LAN works without problem.
Firmware: V2.3.2.114
I have laptops, smartphones, smart switches, smart bulbs, smart cameras and all the devices have the same problem. All devices has reserved ip.
In the logs the only thing I see is a bunch of this:
[DumaOS] DHCP new event., Wednesday, May 19, 2021 20:25:02
[DHCP IP: 192.168.8.42] to MAC address 48:e1:e9:1b:0b:98, Wednesday, May 19, 2021 20:25:02
[DumaOS] DHCP lease change., Wednesday, May 19, 2021 20:24:50
[DumaOS] DHCP new event., Wednesday, May 19, 2021 20:24:50
[DHCP IP: 192.168.8.10] to MAC address 28:c2:1f:72:46:88, Wednesday, May 19, 2021 20:24:50
[DumaOS] DHCP lease change., Wednesday, May 19, 2021 20:24:49
[DumaOS] DHCP new event., Wednesday, May 19, 2021 20:24:49
[DHCP IP: 192.168.8.10] to MAC address 28:c2:1f:72:46:88, Wednesday, May 19, 2021 20:24:49
[DumaOS] Marking device that is marked 192.168.8.50 65 41., Wednesday, May 19, 2021 20:24:49
[DumaOS] DHCP lease change., Wednesday, May 19, 2021 20:24:48
I would appreciate any help
    • conkerick's avatar
      conkerick
      Tutor
      Sorry for the delay. Since the publication of this post, there have been no problems until today.
      At time of posting: I did the update and factory reset.
      Some devices cannot connect to Wi-Fi. I separated the connections with different names, I can't connect to any.
      Log:
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:21:40
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:21:40
      [DHCP IP: 192.168.8.111] to MAC address fc:6b:f0:72:46:b5, Wednesday, June 23, 2021 11:21:40
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:21:30
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:21:30
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:21:30
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:21:19
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:21:19
      [DHCP IP: 192.168.8.106] to MAC address d8:0d:17:20:69:1a, Wednesday, June 23, 2021 11:21:19
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:21:14
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:21:14
      [DHCP IP: 192.168.8.104] to MAC address 68:ff:7b:e8:7a:e8, Wednesday, June 23, 2021 11:21:14
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:21:13
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:21:13
      [DHCP IP: 192.168.8.109] to MAC address 68:ff:7b:e8:5b:28, Wednesday, June 23, 2021 11:21:13
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:21:07
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:21:07
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:21:07
      [DHCP IP: 192.168.8.100] to MAC address 98:da:c4:50:1e:f8, Wednesday, June 23, 2021 11:21:07
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:21:04
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:21:04
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:21:04
      [DHCP IP: 192.168.8.100] to MAC address 98:da:c4:50:1e:f8, Wednesday, June 23, 2021 11:21:04
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:21:02
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:21:02
      [DHCP IP: 192.168.8.107] to MAC address 68:ff:7b:e8:6b:99, Wednesday, June 23, 2021 11:21:02
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:21:01
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:21:01
      [DHCP IP: 192.168.8.100] to MAC address 98:da:c4:50:1e:f8, Wednesday, June 23, 2021 11:21:01
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:20:59
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:20:59
      [DHCP IP: 192.168.8.102] to MAC address 68:ff:7b:e8:65:0c, Wednesday, June 23, 2021 11:20:59
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:20:56
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:20:56
      [DHCP IP: 192.168.8.102] to MAC address 68:ff:7b:e8:65:0c, Wednesday, June 23, 2021 11:20:56
      [DoS Attack: ACK Scan] from source: 35.195.81.93, port 443, Wednesday, June 23, 2021 11:20:41
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:20:31
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:20:31
      [DHCP IP: 192.168.8.121] to MAC address 8c:ce:4e:f6:5d:04, Wednesday, June 23, 2021 11:20:31
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:20:30
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:20:30
      [DHCP IP: 192.168.8.106] to MAC address d8:0d:17:20:69:1a, Wednesday, June 23, 2021 11:20:30
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:20:28
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:20:28
      [DHCP IP: 192.168.8.103] to MAC address 98:da:c4:c8:24:18, Wednesday, June 23, 2021 11:20:28
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:20:27
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:20:27
      [DHCP IP: 192.168.8.106] to MAC address d8:0d:17:20:69:1a, Wednesday, June 23, 2021 11:20:27
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:20:24
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:20:24
      [DHCP IP: 192.168.8.121] to MAC address 8c:ce:4e:f6:5d:04, Wednesday, June 23, 2021 11:20:24
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:20:21
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:20:21
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:20:21
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:20:12
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:20:12
      [DHCP IP: 192.168.8.103] to MAC address 98:da:c4:c8:24:18, Wednesday, June 23, 2021 11:20:12
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:20:00
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:20:00
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:20:00
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:19:54
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:19:54
      [DHCP IP: 192.168.8.108] to MAC address 98:da:c4:c8:1e:ab, Wednesday, June 23, 2021 11:19:54
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:19:43
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:19:43
      [DHCP IP: 192.168.8.107] to MAC address 68:ff:7b:e8:6b:99, Wednesday, June 23, 2021 11:19:43
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:19:38
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:19:38
      [DHCP IP: 192.168.8.121] to MAC address 8c:ce:4e:f6:5d:04, Wednesday, June 23, 2021 11:19:38
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:19:21
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:19:21
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:19:21
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:19:11
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:19:11
      [DHCP IP: 192.168.8.102] to MAC address 68:ff:7b:e8:65:0c, Wednesday, June 23, 2021 11:19:11
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:19:09
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:19:09
      [DHCP IP: 192.168.8.108] to MAC address 98:da:c4:c8:1e:ab, Wednesday, June 23, 2021 11:19:09
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:19:08
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:19:08
      [DHCP IP: 192.168.8.102] to MAC address 68:ff:7b:e8:65:0c, Wednesday, June 23, 2021 11:19:08
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:19:05
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:19:05
      [DHCP IP: 192.168.8.101] to MAC address 98:da:c4:c8:27:57, Wednesday, June 23, 2021 11:19:05
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:59
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:18:59
      [Time synchronized with NTP server] Wednesday, June 23, 2021 11:18:46
      [DoS Attack: ACK Scan] from source: 162.254.192.108, port 443, Wednesday, June 23, 2021 11:18:39
      [DoS Attack: ACK Scan] from source: 162.254.192.108, port 443, Wednesday, June 23, 2021 11:18:38
      [DoS Attack: ACK Scan] from source: 162.254.192.108, port 443, Wednesday, June 23, 2021 11:18:37
      [DoS Attack: ACK Scan] from source: 162.254.192.108, port 443, Wednesday, June 23, 2021 11:18:36
      [DoS Attack: ACK Scan] from source: 162.254.192.108, port 443, Wednesday, June 23, 2021 11:18:35
      [DoS Attack: ACK Scan] from source: 162.254.192.108, port 443, Wednesday, June 23, 2021 11:18:34
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:33
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:33
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:18:33
      [DoS Attack: ACK Scan] from source: 162.254.192.108, port 443, Wednesday, June 23, 2021 11:18:33
      [DoS Attack: ACK Scan] from source: 162.254.192.108, port 443, Wednesday, June 23, 2021 11:18:32
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:32
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:32
      [DHCP IP: 192.168.8.121] to MAC address 8c:ce:4e:f6:5d:04, Wednesday, June 23, 2021 11:18:32
      [DoS Attack: ACK Scan] from source: 162.254.192.108, port 443, Wednesday, June 23, 2021 11:18:31
      [DoS Attack: ACK Scan] from source: 162.254.192.108, port 443, Wednesday, June 23, 2021 11:18:30
      [DoS Attack: ACK Scan] from source: 35.172.244.163, port 443, Wednesday, June 23, 2021 11:18:29
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:29
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:29
      [DHCP IP: 192.168.8.121] to MAC address 8c:ce:4e:f6:5d:04, Wednesday, June 23, 2021 11:18:29
      [DoS Attack: ACK Scan] from source: 52.43.232.245, port 8883, Wednesday, June 23, 2021 11:18:25
      [DoS Attack: ACK Scan] from source: 35.172.244.163, port 443, Wednesday, June 23, 2021 11:18:15
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:14
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:14
      [DHCP IP: 192.168.8.107] to MAC address 68:ff:7b:e8:6b:99, Wednesday, June 23, 2021 11:18:14
      [DoS Attack: ACK Scan] from source: 35.172.244.163, port 443, Wednesday, June 23, 2021 11:18:13
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:11
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:11
      [DHCP IP: 192.168.8.103] to MAC address 98:da:c4:c8:24:18, Wednesday, June 23, 2021 11:18:11
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:10
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:10
      [DHCP IP: 192.168.8.102] to MAC address 68:ff:7b:e8:65:0c, Wednesday, June 23, 2021 11:18:10
      [DoS Attack: ACK Scan] from source: 35.172.244.163, port 443, Wednesday, June 23, 2021 11:18:09
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:07
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:07
      [DHCP IP: 192.168.8.102] to MAC address 68:ff:7b:e8:65:0c, Wednesday, June 23, 2021 11:18:07
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:05
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:05
      [DHCP IP: 192.168.8.109] to MAC address 68:ff:7b:e8:5b:28, Wednesday, June 23, 2021 11:18:05
      [DoS Attack: ACK Scan] from source: 52.43.232.245, port 8883, Wednesday, June 23, 2021 11:18:05
      [DoS Attack: ACK Scan] from source: 35.169.31.55, port 443, Wednesday, June 23, 2021 11:18:05
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:04
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:04
      [DHCP IP: 192.168.8.104] to MAC address 68:ff:7b:e8:7a:e8, Wednesday, June 23, 2021 11:18:04
      [DoS Attack: ACK Scan] from source: 35.169.31.55, port 443, Wednesday, June 23, 2021 11:18:03
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:03
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:03
      [DHCP IP: 192.168.8.101] to MAC address 98:da:c4:c8:27:57, Wednesday, June 23, 2021 11:18:03
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:02
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:02
      [DHCP IP: 192.168.8.121] to MAC address 8c:ce:4e:f6:5d:04, Wednesday, June 23, 2021 11:18:02
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:18:01
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:18:01
      [DHCP IP: 192.168.8.109] to MAC address 68:ff:7b:e8:5b:28, Wednesday, June 23, 2021 11:18:01
      [Time synchronized with NTP server] Wednesday, June 23, 2021 11:18:00
      [DoS Attack: ACK Scan] from source: 35.172.244.163, port 443, Wednesday, June 23, 2021 11:18:00
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:59
      [DHCP IP: 192.168.8.101] to MAC address 98:da:c4:c8:27:57, Wednesday, June 23, 2021 11:17:59
      [Internet connected] IP address: 172.16.0.2, Wednesday, June 23, 2021 11:17:55
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:51
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:51
      [DHCP IP: 192.168.8.106] to MAC address d8:0d:17:20:69:1a, Wednesday, June 23, 2021 11:17:51
      [Internet disconnected] Wednesday, June 23, 2021 11:17:37
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:25
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:25
      [DHCP IP: 192.168.8.107] to MAC address 68:ff:7b:e8:6b:99, Wednesday, June 23, 2021 11:17:25
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:24
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:24
      [DHCP IP: 192.168.8.121] to MAC address 8c:ce:4e:f6:5d:04, Wednesday, June 23, 2021 11:17:24
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:23
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:23
      [DHCP IP: 192.168.8.106] to MAC address d8:0d:17:20:69:1a, Wednesday, June 23, 2021 11:17:22
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:22
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:22
      [DHCP IP: 192.168.8.103] to MAC address 98:da:c4:c8:24:18, Wednesday, June 23, 2021 11:17:22
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:21
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:21
      [DHCP IP: 192.168.8.102] to MAC address 68:ff:7b:e8:65:0c, Wednesday, June 23, 2021 11:17:21
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:20
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:20
      [DHCP IP: 192.168.8.107] to MAC address 68:ff:7b:e8:6b:99, Wednesday, June 23, 2021 11:17:20
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:18
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:18
      [DHCP IP: 192.168.8.106] to MAC address d8:0d:17:20:69:1a, Wednesday, June 23, 2021 11:17:18
      [DHCP IP: 192.168.8.103] to MAC address 98:da:c4:c8:24:18, Wednesday, June 23, 2021 11:17:18
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:16
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:16
      [DHCP IP: 192.168.8.109] to MAC address 68:ff:7b:e8:5b:28, Wednesday, June 23, 2021 11:17:16
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:15
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:15
      [DHCP IP: 192.168.8.105] to MAC address 68:ff:7b:e8:6b:38, Wednesday, June 23, 2021 11:17:15
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:14
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:14
      [DHCP IP: 192.168.8.101] to MAC address 98:da:c4:c8:27:57, Wednesday, June 23, 2021 11:17:14
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:17:12
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:17:12
      [DHCP IP: 192.168.8.109] to MAC address 68:ff:7b:e8:5b:28, Wednesday, June 23, 2021 11:17:12
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:16:44
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:16:44
      [DHCP IP: 192.168.8.101] to MAC address 98:da:c4:c8:27:57, Wednesday, June 23, 2021 11:16:44
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:16:37
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:16:37
      [DHCP IP: 192.168.8.100] to MAC address 98:da:c4:50:1e:f8, Wednesday, June 23, 2021 11:16:37
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:16:35
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:16:35
      [DHCP IP: 192.168.8.100] to MAC address 98:da:c4:50:1e:f8, Wednesday, June 23, 2021 11:16:35
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:16:31
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:16:31
      [DHCP IP: 192.168.8.109] to MAC address 68:ff:7b:e8:5b:28, Wednesday, June 23, 2021 11:16:31
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:16:17
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:16:17
      [DHCP IP: 192.168.8.100] to MAC address 98:da:c4:50:1e:f8, Wednesday, June 23, 2021 11:16:17
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:16:08
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:16:08
      [DHCP IP: 192.168.8.127] to MAC address fc:6b:f0:ce:a1:03, Wednesday, June 23, 2021 11:16:08
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:16:02
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:16:02
      [DHCP IP: 192.168.8.102] to MAC address 68:ff:7b:e8:65:0c, Wednesday, June 23, 2021 11:16:02
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:16:01
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:16:01
      [DHCP IP: 192.168.8.107] to MAC address 68:ff:7b:e8:6b:99, Wednesday, June 23, 2021 11:16:01
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:15:57
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:15:57
      [DHCP IP: 192.168.8.109] to MAC address 68:ff:7b:e8:5b:28, Wednesday, June 23, 2021 11:15:57
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:15:54
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:15:54
      [DHCP IP: 192.168.8.100] to MAC address 98:da:c4:50:1e:f8, Wednesday, June 23, 2021 11:15:54
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:15:47
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:15:47
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:15:47
      [DumaOS] Cloudsync Ping Heatmap result 'true','nil', Wednesday, June 23, 2021 11:15:43
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:15:38
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:15:38
      [DHCP IP: 192.168.8.105] to MAC address 68:ff:7b:e8:6b:38, Wednesday, June 23, 2021 11:15:38
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:15:31
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:15:31
      [DHCP IP: 192.168.8.103] to MAC address 98:da:c4:c8:24:18, Wednesday, June 23, 2021 11:15:31
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:15:26
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:15:26
      [DHCP IP: 192.168.8.101] to MAC address 98:da:c4:c8:27:57, Wednesday, June 23, 2021 11:15:26
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:15:25
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:15:25
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:15:25
      [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Wednesday, June 23, 2021 11:15:05
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:15:01
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:15:01
      [DHCP IP: 192.168.8.100] to MAC address 98:da:c4:50:1e:f8, Wednesday, June 23, 2021 11:15:01
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:15:00
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:15:00
      [DHCP IP: 192.168.8.103] to MAC address 98:da:c4:c8:24:18, Wednesday, June 23, 2021 11:15:00
      [DumaOS] Marking device that is marked 192.168.8.128 32 26., Wednesday, June 23, 2021 11:14:52
      [DumaOS] applying qos for zone lan, Wednesday, June 23, 2021 11:14:52
      [DumaOS] applying qos for zone wan, Wednesday, June 23, 2021 11:14:52
      [DumaOS] Marking device that is marked 192.168.8.128 32 26., Wednesday, June 23, 2021 11:14:51
      [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Wednesday, June 23, 2021 11:14:51
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:14:51
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:14:51
      [DHCP IP: 192.168.8.112] to MAC address 24:62:ab:1a:bb:95, Wednesday, June 23, 2021 11:14:51
      [DumaOS] DHCP new lease allocated., Wednesday, June 23, 2021 11:14:50
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:14:50
      [DHCP IP: 192.168.8.128] to MAC address fc:6b:f0:d9:ca:78, Wednesday, June 23, 2021 11:14:50
      [DumaOS] DHCP lease change., Wednesday, June 23, 2021 11:14:46
      [DumaOS] DHCP new event., Wednesday, June 23, 2021 11:14:46
      After serveral reboots, it's working now.
      Please help.
      Thank you.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Could you try reserving IP addresses for the devices in LAN Settings and see whether it is more stable then?
