- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Xfinity speeds now half with upgrade to CM2000 modem + XR1000 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
ISP: xfinity
Internet Plan: Blast! Pro + Internet (speeds up to 400Mbps)
Replaced my AC1750 cable modem router (c6300) that was previously on the same xfinity internet plan. Speedtest.net tested wifi at a consistent +450Mbps down / 11.5Mbps up. Laptop hardwired in Speedtest.net tested again at a consistent +450Mbps down / 11.5Mbps up. Both with consistent 19ms ping, 2.2ms jitter, and 0% packet loss.
However, my hardwired ps5 Test Internet Connection test results were not as good, with inconsistent numbers ranging from 89-270Mbps down / 500Kbps-11Mbps up. Ps5 over wifi was consistent at 120Mbps down / 11Mbps up. (note: I've tried multiple ca6 cables with no luck)
The purpose of purchasing the CM2000 and XR1000 was to get greater consistent speeds that I'm paying Xfinity for. I've restarted both the modem and router numerous times and ran speedtest.net inbetween with no change in data. The odd part is that the XR1000 Duma OS has a Connection Benchmark feature and when I run the test it reads:
Down: 387Mbps
Up: 12Mbps
Average ping: 17.3ms
Jitter: 0.63ms
Packet loss: 0.00%
Ping Test (under load)
Download: 36.51ms
Upload: 46.08ms
Idle: 18.19
XR1000 firmware version: V1.0.0.58_1.0.44
Why am I not achieving equalto or greater speeds with my new set up over my previous dated modem/router combo??
Help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xfinity speeds now half with upgrade to CM2000 modem + XR1000 router
Thanks for posting, is it just the PS5 that's not seeing full speeds through the XR1000? Do you have any other wired/wireless devices that are also seeing slower speeds?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you configured QoS? If you completely disable it from the three-line menu in Congestion Control, do speeds then increase?
- Mark as New
- Bookmark
- Subscribe
- Permalink
i just disabled QoS and my ps5 did achieve better speeds, but it wasn't as consistent across all devices as I'd hoped.
Test ran between 8:00a - 10:30am
PS5 hardwired
Test 1: 426Mbps/11.5Mbps
Test 2: 395Mbps/11.7Mbps
Test 3: 372Mbps/11.7Mbps
iPhone 11 Pro (speedtest.net app) wifi
Test 1: 309Mbps/11.7Mbps
Test 2: 337Mbps/11.7Mbps
Test 3: 453Mbps/11.2Mbps
Macbook Pro (Late 2011) wifi
Test 1: 224.48Mbps/11.64Mbps
Test 2: 266.30Mbps/11.65Mbps
Test 3: 267.63Mbps/11.85Mbps
Macbook Pro (Late 2011) hardwired with same cat6 ethernet cable from PS5
Test 1: 475.70Mbps/11.69Mbps
Test 2: 474.39Mbps/11.60Mbps
Test 3: 475.56Mbps/11.84Mbps
Kind of a let down that QoS has to be turned off in order to achieve better speeds. I was looking forward to the QoS feature because both my brother and myself game and I wanted to utilize it to help with lag and such. I'm on the PS5 and he's on PC.
How can I configure QoS to achieve equalto or better speeds that my previous dated modem/router?
Devices on my network:
2 smartphones (wifi)
1 smart tv (wifi)
2 laptops (wifi)
PC (wifi)
PS5 (hardwired)
2 security cameras (wifi)
wall ac unit (wifi)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
QoS is currently disabled, but bandwith setting were set to 100% and that setting didn't perform as expected. I also tested the speed to my PS5 by allocating all bandwidth and adding it to the Traffic Prioritizaion list. Again, poor speed and performance which doesn't make much sense since it should have all been going to the ps5 via LAN. Why would utilizing the QoS feature reduce speed and performance?
Also speed flucuations between 50-100Mbps doesn't make sense with my new equipment. I figured that a 32x8 docsis 3.1 with a wifi 6 gaming router would provide more stable speeds for all devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just looked at the setting you mentioned, and I had not touched it previously. When I just opened it it's currently set at 387.52Mbps/12.5Mbps. Would it be better for me to raise the Bandwidth Speeds to the speeds that are actually being tested via Speedtest.net? I had tested the played with the Congestion Control per some other forums and had it set at 70%, which didn't help at all. How I added it was I found and labeled my PS5 under the Device Manager, then added new device to Traffic Prioritization. I reuploaded the images as JPEG.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Perfect. I've adjusted the settings. Will these adjustments help maintain speed and performance while gaming? PS5 and PC typically game at the same time. I appreciate the help so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
