- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Xr500 Issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Xr500 Issue
Not sure where to go with this, or if my XR500 is still working but.
Last night I had major issues with my router and my connection, at first I thought it was my internet connection then I worked out it was the XR500.
I keep getting DNS errors with the router, it started in my Sons room, then moved to my xbox and pc. They would not connect to the router, I'm using power line adaptors, but normally if I just reset them
the internet works again, but not in this case. It got to the point where my computer and xbox wouldn't connect at all.
Wifi devices would connect though, so I reset all the powerline plugs again and still nothing. I tried to log into the router via my phone, even though the internet was working via the phone I could not log into the router settings, every time I tried to go into setting page, it would just take me to the netgear home page, which told me I'm not connected to the router?
So I factory reset the router, still couldn't connect to it after that. At this point I was fuming and ready to smash some thing, so I pulled out an old TP link router, set it up bang on the internet straight away no issues. So I went back to the XR500, it would now connect to my pc? So set it all up again, got every thing working to how I had my setting, thought its all sorted.
Got up this morning, its all off again, nothing will connect via the XR500, phone won't connect to the log in page, put the TP link back in, works straight away...............
Has my XR500 died?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 Issue
Are you on the latest firmware? Have you tried a factory reset? Can you access the XR500's interface when you get disconnected? If not, what IP address are you being given?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 Issue
Is Smart Connect Enabled or disable?
Set 20/40Mhz Coexistence to 40Mhz only
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 Issue
It's a bt open reach modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
