Reply
Xr500 Port Triggering
moose1111
Tutor
i used port trigger for blackops 4 for my pc. is that ok or is port forwarding better. also is there a help phone i could call for other questions. thanks
Message 1 of 3
Netduma-Fraser
NetDuma Partner
Re: Xr500 Port Triggering
Hi Moose, if you have an open NAT that's fine. Port Triggerring is fine as it'll only open the ports you've entered when triggered so if any other devices need to use those ports when you're not gaming they can. When you purchased your router you should have gotten 90 days support I believe. So if you login to your account under http://support.netgear.com/ there should be a number you can call.
Message 2 of 3
moose1111
Tutor
thank u sir
Message 3 of 3
Discussion stats
  • 2 replies
  • 735 views
  • 1 kudo
  • 2 in conversation
Announcements
