- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Xr500 nighthawk no internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model: nighthawk xr500 gaming router
Serial number: 5KD3895A0044F
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 nighthawk no internet
what modem/gateway is it connected to?
What firmware is on the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
its spectrum modem EN2251 model i believe it is, and firmware im not sure on the router because i cant even connect to it after a factory reset. So whatever the default firmware is after factory resetting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
the "default firmware" after a firmware reset is whatever firmware you had installed. It doesn't clear out firmware and bring it back to the original. Resetting only clears out settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
oooh ok so yeah im not sure.. i cant log into the router anymore because it keeps saying no internet detected so i cant fully setup the router anymore.
- Mark as New
- Bookmark
- Subscribe
- Permalink
should still be able to log into router.
try this.
power off the modem and the router and disconnect everything from both. even coax from modem.
Wait 2 minutes.
connect coax back to modem and power it on.
give it 2 minutes to fully boot.
connect lan port on modem to wan port on router.
power on the router.
give it a couple minutes to boot.
try setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK so are you now able to access the interface and setup the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What exactly did you setup manually? Are you referring to the initial setup wizard or QoS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
