× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Xr500 open nat
Ahulee
Xr500 open nat
Am trying to make an static route to my PlayStation but when I select it and put all the ips the destination up don’t let the process continue, even tho I have check and am putting the correct one
Message 1 of 7
Ahulee
Re: Xr500 open nat
I really need gel opening my nat on my PlayStation
Message 2 of 7
Netduma-Fraser
NetDuma Partner
Re: Xr500 open nat
You don't need to do a static route. In WAN Settings just change NAT to open.
Message 3 of 7
Ahulee
Re: Xr500 open nat
Yes but in call of duty still says moderate nat and have internet problems stills
Message 4 of 7
Netduma-Fraser
NetDuma Partner
Re: Xr500 open nat
What is your exact physical setup? Are you using the Geo-Filter? What internet problems are you having?
Message 5 of 7
Ahulee
Re: Xr500 open nat
Yes am using geo filter for 2700 km.. I live in Puerto Rico and am using a “Claro gateway of fiber like the one used is USA like at&t. Y got it with pan to my ps4 but there no option I can pick that give me open nat, I have tried for days
Message 6 of 7
Netduma-Fraser
NetDuma Partner
Re: Xr500 open nat
Can you put the gateway in bridge or modem mode or does it have a DMZ function?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1040 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
