Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Xr500 vlan201
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-11-18
01:32 PM
2021-11-18
01:32 PM
Xr500 vlan201
Hello, I have a problem connecting my router to the modem, the modem use iPoe vlan-201
and I was trying to connect my xr500 via transparent bridging but it’s not working, on dumaos it tells me that the wan ip address is 192.168.0.3
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-11-18
02:20 PM
2021-11-18
02:20 PM
Re: Xr500 vlan201
If that is your IP then the bridging hasn't worked at all and it is still in router mode. You can have the modem in router mode and put the XR WAN IP in its DMZ instead, then connect all devices to the XR and it will work just as well.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-11-18
03:18 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-11-18
03:26 PM
2021-11-18
03:26 PM
Re: Xr500 vlan201
Did you put the WAN IP you mentioned there in it or another? If you put the correct IP in then you may have a CG-NAT, in which case the only way around it is to get a static public IP from the ISP
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-11-18
04:13 PM
2021-11-18
04:13 PM
Re: Xr500 vlan201
I put that wan ip in there, I will try with static ip
Message 5 of 5
Announcements
