×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Xr500
Davidddr
Xr500
Not sure what to do only lights that pop up are USB2 & Ethernet. no power light or anything else are working. Cannot connect to the app.
Anybody have a solution to fix this? Thanks
Message 1 of 5
Netduma-Fraser
NetDuma Partner
Re: Xr500
If those lights are appearing then the router will be powered on so maybe a faulty LED there. Can you access the interface using a wired PC?
Message 2 of 5
Davidddr
Re: Xr500
Yes the router is powered on but from what ive seen others talk about I think it’s “ bricked” . I have a laptop accessible to use
Message 3 of 5
Netduma-Fraser
NetDuma Partner
Re: Xr500
Can you access the interface with the laptop?
Message 4 of 5
Guru
Re: Xr500
What happens if you press the reset button for 10 seconds then release?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 5 of 5
Discussion stats
  • 4 replies
  • 590 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
