× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Xr700 Bandwidth Allocation QOS
Gardone8876
Guide
How can I set a device to receive 50mbps? Everytime a new device is added the speed decreases in Bandwidth Allocation. Or do I even need to touch the setting?
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 7
Accepted Solutions
Netduma_Jack
NetDuma Partner
Re: Xr700 Bandwidth Allocation QOS
You got it - we'll work on a 'lock bandwidth' feature to set this in place. Thanks for letting us know you'd like this feature.
Message 5 of 7
All Replies
Guru
What happens if you don't touch anything and just add a device?
Message 2 of 7
Gardone8876
Guide
The percentages keep on decreasing. I found the answer on another thread. The way it works it will keep decreasing the percentage based on devices added. A feature needs to be added to lock the value to a number. Thanks for the help.
Message 3 of 7
Guru
Thanks for letting us know.
Enjoy.
Message 4 of 7
Netduma_Jack
NetDuma Partner
Message 5 of 7
Guru
Message 6 of 7
Gardone8876
Guide
Thanks for letting me know about the firmware update. I have an android app that notifies me anytime the webpage updates. Keep up the good work. Can't wait to see the feature added.
Message 7 of 7
Discussion stats
  • 6 replies
  • 2800 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
