× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
You will need a VDSL2/FTTC router to use our service...
DizeeSpellz
Ok so Im looking to change my internet from BT to IDNET
IDNET says I need a VDSL2/FTTC router to use their service
Is the Nighthawk XR300 compatible?
If not I do have a Netduma R1 but think I will need a modem with VDSL2 capabilities
If I just get the XR300 will it work?
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 4
Netduma_Alex
NetDuma Partner
Re: You will need a VDSL2/FTTC router to use our service...
No, the XR300 is not a modem, you'll still need a modem.
I have BT VDSL at home and I use a DrayTek Vigor which works quite well.
I'm sure there's a Netgear modem available that does VDSL. Unfortunately there is no DumaOS product currently that contains a router, VDSL or otherwise.
Message 2 of 4
Netduma_Alex
NetDuma Partner
Oops I meant to say, there is no DumaOS product that contains a MODEM. They're all routers!
Message 3 of 4
DizeeSpellz
AAHH hey Alex Smiley LOL
Ok thanks, thought the netgear ones where aio
Message 4 of 4
Discussion stats
  • 3 replies
  • 1179 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
