× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
black ops 4 PING
black ops 4 PING
hi all,i am a bit confused with which ping numbers to go by as i am getting 22ms ping through DumaOS but when i check ping meter within black ops 4 network options ping  actually fluctuates between 65ms-120ms and never at anytime does it go under 50ms i strongly believe black ops 4 ping is my actual ping as ive got 3 days playing time on black ops 4 and online multiplayer experience has been rough i know the closest dedicated server is about 700 kilometres from my location and just  wondering what ping i should actually be getting my internet speeds 60down 35up if that helps
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 2
Netduma_Jack
NetDuma Partner
Re: black ops 4 PING
Hi there - try following this guide for best Geo-Filter setup:
http://support.netduma.com/en/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-g...
There's a lot that goes into measuring ping - the game is not particularly accurate. Here's an older thread from the Netduma forums about BO3, where the same thing was discussed: http://forum.netduma.com/topic/9117-how-accurate-is-the-in-game-ping-system-b03/
Message 2 of 2
Discussion stats
  • 1 reply
  • 1330 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
